#1 2020-08-28 06:31:11
marco.mueller
Arbitrary ABNORMAL_ABORT after solver calculation
my DYNA_NON_LINE simulation runs fine, until the post processing starts and then stops at arbitrary points without error message:
- After the last iteration
- While CALC_CHAMP
- While IMPR_RESU (see attached case)
Two out of ten runs, in which I tried different number of time step size / simulation time (and thus file size) were successfully finalised. Unfortunately not just the smallest ones.
I'm using Salome-Meca 9.3.0 / CA 14.4 on Windows 10.
Has anyone seen this behavior before?
Marco
#2 2020-08-28 08:07:41
Re: Arbitrary ABNORMAL_ABORT after solver calculation
if you can share mesh file.
message shows 0, means solver run is successful.
some problem with definition in cal champ.
send mesh file.
#3 2020-09-01 14:38:12
marco.mueller
unfortunately I'm not allowed to share the mesh files.
Any other idea?
#4 2020-09-23 08:51:04
marco.mueller
Has nobody seen this before? To me it seems to be related to the MS Windows implementation.
