From the output you have shown viz.
./create_appli.sh: line 263: python: command not found
it appears that there is still python name error.
1. Please make sure that you followed the step no 4 and 6 described in my post.
2. Following all the steps serially is important.
3. Only this much I can say now, based on your report.
Hope this helps.
Please let us know here, whether this works or not.
Regards.
Hi Sukumar,
Thanks a lot. I followed the procedure again as per your suggestion. It worked!
But I have same message as Roger has about the Europlexus module. I decided to ignore it for now.
Thanks and regards,
Hems
Hi there,
I followed instruction and install Salome-Meca, but still having problem with installation. Here what I got after installation:
amvali@amvali-VirtualBox:~$ ./salome_meca-2019.0.3-1-universal.run
Self Extracting salome_meca V2019.0.3_universal Installer
Enter the salome_meca install directory [default=/home/amvali/salome_meca] : salome_meca is in English, do you want to be in French ? [y/N] : n
Installation of salome_meca V2019.0.3_universal in /home/amvali/salome_meca/V2019.0.3_universal ...
All good.
Done
Creating salome_meca application in /home/amvali/salome_meca/appli_V2019.0.3_universal ...
To run the application:
$ /home/amvali/salome_meca/appli_V2019.0.3_universal/salome
Adjusting wishexecutable /home/amvali/salome_meca/V2019.0.3_universal/tools/Code_aster_frontend-20190/etc/codeaster/profile.sh
Final configuration
Would you please help me?
Thanks,
Ali
Hello, you teach me a lot zohir about the instalation, but all theses problems can be solutioned installing python before salome
>>sudo apt install python
It's a prerequisite that is not mentioned
So will not be needed change python to python2 on the instalation file
But the aster_study will not work yet, so download this package libffi6_3.2.1-9_amd64.deb.
After this, open terminal in Downloads location.
>>sudo dpkg -i libffi6_3.2.1-9_amd64.deb
This is for manually install the package.
Now all should be fine.
Thanks zohir.
Thank you sb1966. It is worked like a magic.
Installation of Salome-meca2019.0.3 in Xubuntu 20.04 was successful with these following minimalistic steps,
unlike the detailed python reinstall as described in the previous reply by ckrug. My steps are as follows:1. Install all the prerequisites listed in forum (c-a.org/V2/spip.php?article 273).
sudo apt-get install python3-dev sudo apt-get install python3-numpy sudo apt-get install tcl tk sudo apt-get install bison sudo apt-get install flex sudo apt-get install liblapack-dev sudo apt-get install libblas-dev sudo apt-get install libopenblas-dev
2. Make sure also to install libopenblas-base.
sudo apt-get install libopenblas-base
This is essential to avoid "Exit error=127" later while running code-aster (AsterStudy)
3. Install the requisite qt5 pacakges and net-tools etc as described in forum post php?id=24470
sudo apt-get install libqt5pengl5 sudo apt-get install libqt5concurrent5 sudo apt-get install libqt5opengl5 sudo apt-get install libqt5multimediawidgets5 sudo apt-get install net-tools sudo apt-get install libnlopt0
4. install python2, named python2-minimal in ubuntu 20.04:
sudo apt-get install python2-minimal
5. Install salome-meca following usual procedure.
5a. This will not create the application, but creates a script create_appl.sh.
6. edit the file to change "python" to "python2" in all its occurences (it occurs three times), as zohir described in one of his posts in this page.
6a. Then run this edited file in terminal:./create_appli.sh
This will install the application along with the desktop icon.7. Install liffi6.3.2 as described earlier in this page.
viz.:wget -O $HOME/Downloads/libffi6_3.2.1-9_amd64.deb http://ftp.br.debian.org/debian/pool/main/libf/libffi/libffi6_3.2.1-9_amd64.deb sudo dpkg -i $HOME/Downloads/libffi6_3.2.1-9_amd64.deb
8. Create symbolic link of libffi.so.6 as follows:
cd ~/salome_meca/V2019.0.3_universal/prerequisites/debianForSalome/lib ln -s /usr/lib/x86_64-linux-gnu/libffi.so.6 libffi.so.6
9. remove or rename libstdc++.so* files in ~/salome_meca/V2019.0.3_universal/prerequisites/debianForSalome/lib
mv libstdc++.so _libstdc++.so mv libstdc++.so.6 _libstdc++.so.6 mv libstdc++.so.6.0 _libstdc++.so.6.0 mv libstdc++.so.6.0.22 _libstdc++.so.6.0.22
This was essential to avoid opengl error in my case.
EDIT: This issue was also discussed in ___/forum2/viewtopic.php?id=24956
10. Now salome-meca-2019 can be invoked normally.
Hope this helps someone.
Best regards
Happy to know that it was helpful for you.
Best wishes..
Hello everyone,
I am currently struggling to install Salome_meca20 on my new PC and can't figure out how to solve the problem.
So far I followed the procedure described in Post:20
But when i try to run the create_appli.sh file I get the error message:
./create_appli.sh
Enter salome_meca virtual application directory [default=/home/mbaess/salome_meca/appli_V2020.0.1_universal_universal] : Creating salome_meca application in /home/mbaess/salome_meca/appli_V2020.0.1_universal_universal ...
Setting for help already set
Adjusting the file : /home/mbaess/salome_meca/appli_V2020.0.1_universal_universal/SalomeApp.xml
Warning: the directory /home/mbaess/salome_meca/V2020.0.1_universal_universal/modules/EUROPLEXUS_20200/lib/salome is in a path variable but does not exist
Warning: the directory /home/mbaess/salome_meca/V2020.0.1_universal_universal/modules/MELIDEFX_V9_4_0/lib/salome is in a path variable but does not exist
./create_appli.sh: line 301: syntax error near unexpected token `fi'
./create_appli.sh: line 301: `fi'
Does anyone know how to handle this problem?
Thanks alot.
regards,
Moritz
Hi Moritz,
This post is not really a reply to your query, but something related to it, which, I thought of sharing..
1. Please note that earlier post #20 was meant for installing salomeMeca2019.0.3 in Ubuntu 20.04. Hence this does not necessarily ensure that it will work for salome-meca 2020 also. However, it is good that you have tried and let us know that it didn't work.
2. I have not tried installing Salome-meca 2020 yet on Ubuntu 20.04.
3. However, I have installed Salome-meca 2020 in Ubuntu 18.04 without any hassle and it has worked smoothly for simple MECA_STATIQUE analysis of an elastic body.
4. I have not tried yet any complicated analysis in salome-meca 2020. I hope it will work for such analyses too.
Best regards
Thank you for your answer,
On my old Laptop it was running fine Ubuntu20.04, but I cant remember how I solved it. I thought I followed your post, but apparently I didnt.
maybe I will try Ubuntu 18.04 instead.
regards,
Moritz
This worked for me installing SM 2020.0.1 on Ubuntu 20.04. Thank you!
Best regards
Happy to know that the same procedure has worked for SM 2020.0.1 also.
Best regards.
Hi community!
I encountered failures during installation singularity-container on my Ubuntu 20.04. Singularity is vital for the newest S_M 2021. For me helped belowed snippet (unfortunately i'm not allowed to paste direct link), which one I'd like to share:
Source: github ' How can I get singularity container on Ubantu 20.04 #5390 ' issue
Luckily for those not wanting to compile from source, most of the binaries in the (well maintained) EPEL EL8 singularity 3.8.x rpm are static linked, so it is one of the cleaner conversions using alien:
$ grep PRETTY_NAME /etc/os-release
PRETTY_NAME="Ubuntu 20.04.2 LTS"
$ alien --version
alien version 8.95
# WARNING: singularity version numbers subject to change, browse the yum repo to get up-to-date URL
wget https:/ /dl.fedoraproject.org/pub/epel/8/Everything/x86_64/Packages/s/singularity-3.8.0-1.el8.x86_64.rpm
$ sudo alien -d singularity-3.8.0-1.el8.x86_64.rpm
$ sudo apt-get install ./singularity_3.8.0-2_amd64.deb
$ singularity --version
singularity version 3.8.0-1.el8
Hope this answer will help someone else.
Filjan
This worked for me on Xubuntu 20.04
sudo apt-get update && \
sudo apt-get install -y build-essential \
libseccomp-dev pkg-config squashfs-tools cryptsetup
sudo rm -r /usr/local/go
export VERSION=1.13.15 OS=linux ARCH=amd64 # change this as you need
wget -O /tmp/go${VERSION}.${OS}-${ARCH}.tar.gz https://dl.google.com/go/go${VERSION}.${OS}-${ARCH}.tar.gz && \
sudo tar -C /usr/local -xzf /tmp/go${VERSION}.${OS}-${ARCH}.tar.gz
echo 'export GOPATH=${HOME}/go' >> ~/.bashrc && \
echo 'export PATH=/usr/local/go/bin:${PATH}:${GOPATH}/bin' >> ~/.bashrc && \
source ~/.bashrc
curl -sfL https://install.goreleaser.com/github.com/golangci/golangci-lint.sh |
sh -s -- -b $(go env GOPATH)/bin v1.21.0
mkdir -p ${GOPATH}/src/github.com/sylabs && \
cd ${GOPATH}/src/github.com/sylabs && \
git clone https://github.com/sylabs/singularity.git && \
cd singularity
git checkout v3.6.3
cd ${GOPATH}/src/github.com/sylabs/singularity && \
./mconfig && \
cd ./builddir && \
make && \
sudo make install
singularity version
Hi folks,
I follow the steps by Sukumar, but did not work well, my Salome meca appear the same error, the file 'appli_V2019.0.3_universal" is empty.
Best regards
Eduardo Serenza
Please give little more details of your problem. Are you in Ubuntu 20.04? What is your python version?
Meanwhile, you may try the new version 2021 provided in singularity container. This is advantageous because all the prerequisites are already installed in the container. There are number of posts in the forum to help installation e.g. post id=25980 and others.
Best regards.
eduserenza wrote:I follow the steps by Sukumar, but did not work well, my Salome meca appear the same error, the file 'appli_V2019.0.3_universal" is empty.
Meanwhile, you may try the new version 2021 provided in singularity container. This is advantageous because all the prerequisites are already installed in the container. There are number of posts in the forum to help installation e.g. post id=25980 and others.Best regards.
Hi Sukumar, now I got perfect the steps for installation, I`ve Ububtu 20.04, However I am follow your advice in install Salome_meca 2021.
Thxs so much!
Hello
i try to install salome meca 2019.0.3 in ubuntu 20.04 ...all prosseces of insatllation are ok and done without any error ...but after insatllation finish the salome lancer is don t created and don t found...
Hi, I met the same problem as you. I finish the installation and also can not find salome launcher. Did you finally solve this problem and made code aster in the salome meca work?
Hi Sukumar,
Thank you for posting your solution. Now SM is working just fine.
Gilberto
Hi Sukumar,Thank you for posting your solution. Now SM is working just fine.
Hi Gilberto,
Glad to know that it was of help.
BTW, the latest version (2021) is based on singularity container and you don't need to worry about any prerequisite. I think you may try installing that too. And there is another container with mpi enabled. You may browse this forum for the help on the same. (e.g. https /code-aster.org/forum2/viewtopic.php?id=25980)
Best regards
