#1 2020-04-26 02:11:33
toothless
2018 is working, Sigsev Fault on 2019 for Ubuntu 18.04
Hello all,
OS:  Ubuntu 18.04 (physical installation)
GPU: Radeon RX 460
I am having an issue where I get "Segmentation Violations" errors when I try to run Salome-Meca 2019 and enter the mesh module, causing the program to crash.  I see that others have made similar posts, and I have tried some of their solutions (hopefully this compiled list will help others with these problems).  I HAVE gotten Salome-Meca 2018 to work using the libstdc++ trick below.
- Installed all prerequisites
code-aster.org/IMG/pdf/sm2019_ubuntu18_install.pdf
- Install OEM drivers for graphics card (Radeon RX460)
- Run installation using sudo (sudo ./salome_meca-2019.0.3-1-universal.run)
code-aster.org/forum2/viewtopic.php?id=24678
- I have NOT tried the solution suggested by cbourcier to install mesa-salome and point to those libraries, because it looks like Salome's server is down at the minute.  I did try this previously on a virtaul machine, and while it allowed the program to start, I could still not display a mesh in the AsterStudy, and the solver gave an error "It misses the mesh!", which I assume was related.
code-aster.org/forum2/viewtopic.php?id=23568#p60155
-  Comment out libstdc++ files using underscore (~/salome_meca/V2019.0.3_universal/prerequisites/debianForSalome/lib)
***This solution DID work for 2018, which I AM currently running***
code-aster.org/forum2/viewtopic.php?id=23487
- LD_PRELOAD command before ./salome
code-aster.org/forum2/viewtopic.php?id=23547
I have also attached the output from the terminal for 2018 when I do NOT comment out the libstdc++ files.  Maybe that contains some clues?
Any suggestions on what I can investigate next would be greatly appreciated.  Thank you!
-Mike
#2 2020-04-27 14:36:59
ing.nicola
Re: 2018 is working, Sigsev Fault on 2019 for Ubuntu 18.04
I personally believe that the error lies in the installation with sudo.
The libstdc++ must be commented if you are not in Debian.
Try to install without sudo in default directory.
Comments libstdc++  files.
Execute ./salome.
post the output on terminal.
Nothing else.
#3 2020-04-28 07:56:26
toothless
ing.nicola, thanks for the reply.
Here is the terminal output:
runSalome running on mission-control
Searching Naming Service  + found in 0.1 seconds
Searching /Kernel/Session in Naming Service  ++++Warning: this type (Study,objref) already exists, it will be ignored.
found in 2.0 seconds
Start SALOME, elapsed time :   2.3 seconds
#4 2020-04-28 09:52:25
ing.nicola
once salome is opened, try to work. In terminal should appears new informations
#5 2020-07-11 11:00:34
ubaidulla
Even I am getting same error shown. But still I can open the application. Problem is that when I try to compute the mesh, mesh is not generating. On the terminal it displays the error :
Can't compile vertex shader.
0:1(10): error: GLSL 3.30 is not supported. Supported versions are: 1.10, 1.20, and 1.00 ES
Please help me to sortout this error.
Thank You
--Ubaidulla
#6 2020-07-12 07:53:27
ww.code-aster.org/spip.php?article1112.
refer page no. 2
follow above procedure to bypass graphic card.
#7 2020-07-16 06:05:06
ubaidulla
Thank you Sameer..
I followed all steps mentioned in page 2 and now I am not getting GLSL error. I am able to compute mesh without error. But I continue to get the warning mentioned above while launching ./salome. I am running on physical system  (ubuntu 18.04) but it does not have graphics card. Is this the reason to get such warning?
Thank you in advance.
#8 2020-07-16 07:20:04
you hv to use ASTK for running solver. Go to Tools, PlugIn, Codeaster, Astk.
as from salome-meca - running solver may crash and takes much more time.
don't worry on your above plugin messages.
