Hi
I'm getting an error when I try to open the Aster-Study module, the error reads "failed to activate module AsterStudy"
Any ideas?
Also, upon installation I receive these errors in the terminal
Warning: the directory /home/USERNAME/bin is in a path variable but doesn't exist
Warning: the directory /home/USERNAME/.local/bin is in a path variable but doesn't exist
Warning: the directory /snap/bin is in a path variable but doesn't exist
Are they related to the aster study module error?
Edit: Update, I received this error when I used the shortcut to run the program on the desktop, when I used the command ./salome in the /salome_meca/appli_V2017.0.2 directory the aster study module opens w/o the error.
Something perhaps to note.
Are the warnings something I should be concerned about?
Thanks,
Dallan
The warnings emitted by the installation process may be safely ignored.
Regarding the different behaviours between the shortcut and the "salome" executable in a terminal, this is quite strange. Thanks for the feedback though. We'll try to look into it.
I also got this error and there was missing python-dateutil. some times even if it is already installed it causes problem. I unistalled and again then installed using following command.
pip uninstall python-dateutil
pip install python-dateutil
after that there was an error
matplotlib requires pyparsing
Then install pyparsing.
pip install pyparsing
It worked for me
Yours Sincerely,
Prafulla
Prafulla Malla
Hi Praful,
Thank you. Your method solved the problem for me.
Hope others also get helped by your solution.
Hİ all,
In my xubuntu, Salome-meca 2017 works well. Today I have decided to install version 2019. I have the same failure when I want to move Asterstudy module. I have checked the python packages that you mention here. In synaptic package manager, it is seen all they are installed. I have to mentioned that in my xubuntu python3(pip3) is installed. I will be appreciated if you can help.
Have a good day.
Hİ all,
Have a good day.
I have solved the problem by installing libffi6_3.2.1-6_amd64.deb to my system.
I hope it helps those with similar problems.
e_aybars wrote:Hİ all,
Have a good day.
Thanks, I solved that problem in this way too.
i have registered, just to say that aster study has now started working for me.
i followed the solution posted by @e_aybars
I am on Ubuntu 20.04 and Salome Meca V2019.0.3
I had the same problem with "AsterStudy module not found".
I solved with the solution posted by e_aybars
You can download the .deb package from here:
h_ttp://ftp.br.debian.org/debian/pool/main/libf/libffi/libffi6_3.2.1-6_amd64.deb
and install with Ubuntu Software
After installation I can use Salome Meca successfully both with the executable
./salome
and by launching Salome Meca from Ubuntu search.
Nicolò
Have a good day.
I similarly solved my problem with this method using libffi6_3.2.1-9_amd64.deb. It can be downloaded here:
packages.debian.org/sid/amd64/libffi6/download
