#1 2020-04-26 22:11:55
zohir
Installation on Ubuntu 20.04
Hello
i try to install salome meca 2019.0.3 in ubuntu 20.04 ...all prosseces of insatllation are ok and done without any error ...but after insatllation finish the salome lancer is don t created and don t found...
#2 2020-04-27 07:38:33
ing.nicola
Re: Installation on Ubuntu 20.04
if is installed in default directory try:
cd $HOME/salome_meca/appli_V2019.0.3_universal
./salome
otherwise subsitute $HOME with your directory.
To create launcher find how to create it  on google . The launcher point to "salome" file in the the.../salome_meca/appli_V2019.0.3_universal directory.
#3 2020-04-27 16:51:27
zohir
thank you for your help i folow your instruction  but the same problem. in the terminal i have this:
zohir@zohir-Aspire-E5-575G:~/Downloads$ '/home/zohir/Downloads/salome_meca-2019.0.3-1-universal.run'
Self Extracting salome_meca V2019.0.3_universal Installer
Enter the salome_meca install directory [default=/home/zohir/salome_meca] : salome_meca is in English, do you want to be in French ? [y/N] : n
Installation of salome_meca V2019.0.3_universal in /home/zohir/salome_meca/V2019.0.3_universal ...
All good.
Done
./create_appli.sh: ligne 108: /salome_prerequisites_root.sh: Aucun fichier ou dossier de ce type
./create_appli.sh: ligne 109: /salome_modules.sh: Aucun fichier ou dossier de ce type
Creating salome_meca application in /home/zohir/salome_meca/appli_V2019.0.3_universal ...
sed: impossible de lire /.config_appli_template.xml: Aucun fichier ou dossier de ce type
Setting for help already set
grep: salome_context.cfg: Aucun fichier ou dossier de ce type
./create_appli.sh: ligne 263: python : commande introuvable
./create_appli.sh: ligne 287: ./salome_post_install.py: Aucun fichier ou dossier de ce type
To run the application:
$ /home/zohir/salome_meca/appli_V2019.0.3_universal/salome
Adjusting wishexecutable /home/zohir/salome_meca/V2019.0.3_universal/tools/Code_aster_frontend-20190/etc/codeaster/profile.sh
Final configuration
zohir@zohir-Aspire-E5-575G:~/Downloads$ cd
zohir@zohir-Aspire-E5-575G:~$ cd salome_meca/appli_V2019.0.3_universal
zohir@zohir-Aspire-E5-575G:~/salome_meca/appli_V2019.0.3_universal$ ./salome
bash: ./salome: Aucun fichier ou dossier de ce type
#4 2020-04-27 17:30:59
ing.nicola
? . This is the installer log .
You have to try to launch salome from script.
However from installer log seems that cannot find folders or the installer file has errors.
verify that folder /home/zohir/salome_meca/appli_V2019.0.3_universal exist
if exist open terminal and digit :
cd /home/zohir/salome_meca/appli_V2019.0.3_universal
./salome
then post the output.
if the folder doesn't exist . Download the installer "salome_meca-2019.0.3-1-universal.run" again. Assure that download and extraction is complete.
#5 2020-04-27 19:15:53
zohir
the appli_V2019.0.3_universal folder exist and when i open i found it to file : appli_V2019.0.3_universal.log, config_appli.xml
and when i appli the command :
zohir@zohir-Aspire-E5-575G:~$ cd /home/zohir/salome_meca/appli_V2019.0.3_universal
#6 2020-04-27 20:22:02
ing.nicola
ok . the installation crashes.
1 -In your log seems that it can't read some files. I think the installation file is corrupted.
If you can , check the file downloaded . Open terminal go in the folder with the downloaded file ( not decompressed)
md5sum salome_meca-2019.0.3-1-universal.tgz
This is a time consuming operation .if md5 is different from 4ea7be35819a53a201d48d189ef1c4d4f6d47e32 the file is invalid.
If the file is invalid or you can't chek md5 sum try to download again the installation file from the site.
Sometimes happens that download is incomplete. Assure that download is completed , decompress the file an assure that decompression is complete.
Delete the folder /home/zohir/salome_meca.
Assure that installation file is readable an executable. Move it  on desktop and in terminal in desktop folder
chmod +x salome_meca-2019.0.3-1-universal.run
reinstall it and post the log of installion again.
Try the code in previous post. ( ./salome)
2 -check always that the prerequisites are installed ( with synaptic application).
 (www.code-aster.org/V2/spip.php?article273)
gcc, g++, gfortran (or other compilers),
cmake,
python3,
python3-dev,
python3-numpy,
tk,
bison,
flex,
liblapack-dev, libblas-dev or libopenblas-dev,
libboost-python-dev (+ libboost-numpy-dev on ubuntu, boost-devel on centos) (for MFront),
zlib (named zlib1g-dev on debian/ubuntu).
I'm sorry. I can't do more.
#7 2020-04-27 23:49:56
zohir
thank you i try..
#8 2020-04-30 22:34:54
1) I have installed all the prerequisites as per
 W_W/code-aster.org/V2/spip.php?article273
and
 W_W/code-aster.org/forum2/viewtopic.php?id=24470
2) I have also installed python2-minimal (named so in 20.04LTS)
3) However, the same problem persists as given below:
4) One forum post said that in Xubuntu 20.04 some one has successfully installed. So I gave it a try, but the same problem arises there too.
5) I thought that it might be due to renaming python to python2 in 20.04. Hence created alias as follows:
 alias python="python2"
in my .bashrc file.
6) However, this too did not solve the problem.
7) Tried to install everything as per the install script given for Ubuntu 18.04. at
 WW_/code-aster.org/...article1112
But installation of libraries failed due to renaming many of them in Ubuntu 20.04/Xubuntu 20.04 repositories
8) Hoping and waiting eagerly to hear from the developers.
Best regards.
#9 2020-05-01 02:01:33
zohir
i think the problem is the python name in ubuntu 20.04, after instalation the salome meca withe an error i edit the file  create_appli.sh and i change all python words by python2 ans save it after i excute this file in terminal ...the installtion continue and i can run salome meca  but i can t open aster stady module
#10 2020-05-01 12:42:47
Jcm
Good morning I have the same problem, I try to explain the procedure I followed:
1. Check the prerequisites and all are fine;
2. Downloaded the file: salome_meca-2019.0.3-1-universal.tgz
3. run on terminal md5sum salome_meca-2019.0.3-1-universal.tgz, i tried to download more than once and check with md5sum, but I never obtain:      4ea7be35819a53a201d48d189ef1c4d4f6d47e32.
4. I installed salome_meca, but I cannot open Aster Study.
I attached a .txt file with the log file of installation and a terminal message when I try to open Aster Study.
Thank you
Claudio
#11 2020-05-02 14:20:24
Jcm
Any solution?
#12 2020-05-02 22:32:12
Irvise
Hi Jcm.
I recently had the same problem with OpenSuse Tumbleweed (OpenSuse's rolling release distro).
The issue stems from libffi.so.6 not being found. The libffi library is a library that binds C code with other languages. In recent months, it had a mayor release and the older version is not compatible with the new one (that is why there is a .6 in it).
Therefore, in order to fix this issue you need to install libffi version 6. I have seen that the version of libffi shipped with 20.04 is version 7. I have searched for the possibility of a pre-packaged libffi6 for 20.04 but it seems no one has done it yet.
I believe you would be better off by building libffi yourself. Make sure you are using the 3.2 version and NOT THE 3.3 one.
Fernando Oleo Blanco
#13 2020-05-04 13:54:06
Jcm
Thanks for your reply mr. Fernando.
If I compile the libffi version 6 (I downloaded libffi-3.2.1.tar.gz) can any issues with other applications occur?
Thanks.
Claudio
#14 2020-05-04 14:50:28
Irvise
Hi Claudio.
There should not be any issues. Programs that are compiled for the new version 3.3, should be linked with libffi.so.7 (or *.so.8, I can't remember). And there should be no issue with the libffi.so.6 library (both can coexist).
There may be a problem if you move the header files, those may collide between versions. However, unless you are doing any development with ffi, everything should be fine.
Fernando
#15 2020-05-04 15:41:25
hafid
I have tried the following in and it works for me at least in manjaro 20.
cd ~/salome_meca/V2019.0.3_universal/prerequisites/debianForSalome/lib
ln -s /usr/lib/libffi.so libffi.so.6
Now I can launch asterstudy module.
#16 2020-05-07 04:44:33
zohir
after downleading and  installion of the    libffi6_3.2.1-9_amd64.deb   manually  now the AsterStudy module started normally.
#17 2020-05-08 17:46:49
Jcm
I confirm, I downloaded the "libffi6_3.2.1-9_amd64.deb" file from Download Page of Debian.
Now I can run Aster-Study
Thank you.
Claudio
#18 2020-05-23 16:17:48
rtrioux
I confirm the suggested solution by  hafid, it worked for me on ArchLinux
#19 2020-06-21 16:26:36
ckrug
Hi, Zohir.
Regarding both python2 and libffi6 issues, the link below offers a solution under "Salome Meca 2019 (Success in 20.04)". Notice that one needs pyenv (addressed earlier in that same page).
# Ref.: https://github.com/dymaxionkim/UbuntuBang/blob/master/README.md
# Python 2 is needed to install
pyenv install anaconda2-2019.07
pyenv activate anaconda2-2019.07
# Install Salome-Meca per https://code-aster.org/forum2/viewtopic.php?id=24750
# Dependency for CodeAster Module
# Ref.: https://www.code-aster.org/forum2/viewtopic.php?id=24883
wget -O $HOME/Downloads/libffi6_3.2.1-9_amd64.deb http://ftp.br.debian.org/debian/pool/main/libf/libffi/libffi6_3.2.1-9_amd64.deb
sudo dpkg -i $HOME/Downloads/libffi6_3.2.1-9_amd64.deb
rm $HOME/Downloads/libffi6_3.2.1-9_amd64.deb
Cheers,
Cristiano
#20 2020-06-25 23:03:50
Installation of Salome-meca2019.0.3 in Xubuntu 20.04 was successful with these following minimalistic steps,
unlike the detailed python reinstall as described in the previous reply by ckrug. My steps are as follows:
1. Install all the prerequisites listed in forum (c-a.org/V2/spip.php?article 273).
sudo apt-get install python3-dev
sudo apt-get install python3-numpy
sudo apt-get install tcl tk
sudo apt-get install bison
sudo apt-get install flex
sudo apt-get install liblapack-dev
sudo apt-get install libblas-dev
sudo apt-get install libopenblas-dev
2. Make sure also to install libopenblas-base.
sudo apt-get install libopenblas-base
This is essential to avoid  "Exit error=127" later while running code-aster (AsterStudy)
3. Install the requisite qt5 pacakges and net-tools etc as described in forum post php?id=24470
sudo apt-get install libqt5pengl5
sudo apt-get install libqt5concurrent5
sudo apt-get install libqt5opengl5
sudo apt-get install libqt5multimediawidgets5
sudo apt-get install net-tools
sudo apt-get install libnlopt0
4. install python2, named python2-minimal in ubuntu 20.04:
sudo apt-get install python2-minimal
5. Install salome-meca following usual procedure.
5a. This will not create the application, but creates a script create_appl.sh.
6. edit the file to change "python" to "python2" in all its occurences (it occurs three times), as zohir described in one of his posts in this page.
6a. Then run this edited file in terminal:
./create_appli.sh
This will install the application along with the desktop icon.
7. Install liffi6.3.2 as described earlier in this page.
viz.:
8. Create symbolic link of libffi.so.6 as follows:
ln -s /usr/lib/x86_64-linux-gnu/libffi.so.6 libffi.so.6
9. remove or rename libstdc++.so* files in ~/salome_meca/V2019.0.3_universal/prerequisites/debianForSalome/lib
mv libstdc++.so _libstdc++.so
mv libstdc++.so.6 _libstdc++.so.6
mv libstdc++.so.6.0 _libstdc++.so.6.0
mv libstdc++.so.6.0.22 _libstdc++.so.6.0.22
This was essential to avoid opengl error in my case.
EDIT: This issue was also discussed in ___/forum2/viewtopic.php?id=24956
10. Now salome-meca-2019 can be invoked normally.
Hope this helps someone.
Best regards
