#1 2018-11-22 09:22:36
GPSalachs
Salome Meca 2017 console error
i am using the Salome Meca 2017 version, when i run an analysis i get the error message :
Last 10000 lines at gio 22 nov 2018 09:21:44 CET...
Cannot read output file or empty file.
Is there a way to correct this so i can see the analysis results while the analysis is running?
Thank you.
#2 2020-06-22 03:03:10
lann
Re: Salome Meca 2017 console error
I also found similar problem in solame Meca 2019 03 。
The messsage is following:
