#1 2020-05-30 17:31:49
michaelherediaperez
SALOME MECA fatal error in UBUNTU 20.04
Hi everyone.
I'm starting to use SALOME MECA 2019 version on UBUNTU 20.04, the installation goes normal, usual warning messages... but one I start with the geometry module a message of FATAL ERROR appears and stop me to work with it, I can not go back or select another option, just have to close the program and that action also is followed by  a FATAL ERROR message.
The FATAL ERROR message is the following:
OpenGl_Window::CreateWindow: glXCreateContext failed.
Does anyone have a solution or know what is happening ?
Thanks!
#2 2020-06-20 18:39:34
ckrug
Re: SALOME MECA fatal error in UBUNTU 20.04
Hi, Michael.
I had the same problem. I followed Jesusbill May 11 post in url=https://community.osarch.org/discussion/67/structural-modelling-of-tensegrity-structures and that apparently solved the issue:
cd ${HOME}/salome_meca/V2019.0.3_universal/prerequisites/debianForSalome/lib
rm libstdc++.so.6.0
ln -s /usr/lib/x86_64-linux-gnu/libstdc++.so.6 libstdc++.so.6
Cheers,
Cristiano
