Hy,
I am trying to install salome meca 2018 on a remote machine running under Ubuntu 18.03.
When I launch salome and connect the GEOM module, the screen is black and no shape can be visualized.
The shell reports this message:
OpenGL driver is too old! Context info:
Version: 1.3 Mesa 4.0.4
But on this machine Mesa is updated:
ubuntu@ip-172-31-16-93:~$ glxinfo | grep "OpenGL version"
OpenGL version string: 3.1 Mesa 19.2.8
Any hint ?
Marco
this pc/laptop hs no graphic card.
u hv to bypass graphic card requirement, procedure given on page 2.
operate solver through astk
ww.code-aster.org/forum2/viewtopic.php?id=24611&p=2
Thank's a lot for your quick reply.
I followed the procedure and GEOM runs correctly.
Without graphic acceleration card the GEOM seems very slow in managing the images.
I have to check in my office with a fiber internet connection.
Is there the same procedure for salome meca 2018 ? Googoling I wasn't able to find something similar.
Marco
you hv to run solver from astk or salome shell to get speed.
2018 same procedure of installation, for without graphic card.
What you mean for run "salome shell" ?
Without GUI ?
If I enforce my AWS EC2 instance with GPU I gain speed in salome meca ?
Marco
