#1 2020-04-24 20:59:20
ing.nicola
[SOLVED] Salome meca Xubuntu 20.04 Crashes to open modules
I'm trying to open salome_meca with   . /salome .
It opens but when i select a module it crash :
runSalome running on cae
Error when trying to access active network connections.
  File "/home/cae/salome_meca/appli_V2019.0.3_universal/bin/salome/PortManager.py", line 111, in __isNetworkConnectionActiveOnPort
    p = Popen(cmd, stdout=PIPE, stderr=STDOUT)
  File "/home/cae/salome_meca/V2019.0.3_universal/prerequisites/Python-365/lib/python3.6/subprocess.py", line 709, in __init__
    restore_signals, start_new_session)
  File "/home/cae/salome_meca/V2019.0.3_universal/prerequisites/Python-365/lib/python3.6/subprocess.py", line 1344, in _execute_child
    raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'netstat': 'netstat'
Searching Naming Service  + found in 0.1 seconds
Searching /Kernel/Session in Naming Service  ++libGL error: MESA-LOADER: failed to open iris (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
libGL error: failed to load driver: iris
libGL error: MESA-LOADER: failed to open swrast (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
libGL error: failed to load driver: swrast
Warning: this type (Study,objref) already exists, it will be ignored.
 found in 1.0 seconds
Start SALOME, elapsed time :   1.1 seconds
The gui show the message attached in the next post
#2 2020-04-24 21:01:08
ing.nicola
Re: [SOLVED] Salome meca Xubuntu 20.04 Crashes to open modules
The message attached
I have python 3.8 .... is it necessary python 3.6 ?
#3 2020-04-26 01:07:13
I  have not tried it. But it seems it is a mesa utilities problem. You may try the following. Please let us know if it works.
 sudo apt install mesa-utils
Then run
 glxgears
For more information and all available GL extensions execute:
 glxgears -info
Hope this helps.
#4 2020-04-26 10:45:27
ing.nicola
I renamed libstdc++.so files in     ....salome_meca/V2019.0.3_universal/prerequisites/debianForSalome/lib.
Now works
#5 2020-09-03 14:45:58
rodrigofarias
Now works
ing.nicola, i have the same problem. You renamed the file to what exactly? You renamed just this file?
Thanks.
#6 2020-09-03 16:34:54
Do the following in ....salome_meca/V2019.0.3_universal/prerequisites/debianForSalome/lib.
mv libstdc++.so _libstdc++.so
mv libstdc++.so.6 _libstdc++.so.6
mv libstdc++.so.6.0 _libstdc++.so.6.0
mv libstdc++.so.6.0.22 _libstdc++.so.6.0.22
