#1 2020-02-03 13:16:44
Deprecated features in the next version
For the 15.2 version
- Modelisation *_UPGB for incompressible cases
  The formulation is not stable
  => use *_UPG or _UPO instead
- Modelisation SHB (solid shells) for plates
  A new more robust element has been developped in a PhD work
- CALC_ESSAI
  Not more usable in the new "pythonic" version of code_aster
  A new tool should been developped in salome_meca environment
- MACR_RECAL
  Use full-python version instead and the new link in salome_meca environment (with ADAO)
- INCLUDE
  Use import Python instead
- POST_T_Q
- MACR_ECLA_PG
  This command was originally developed for reasons of compatibility with GMSH. GMSH now supports MED format natively
  Note: this method will always be used in PROJ_CHAMP for the projection of ELGA fields
#2 2020-02-05 09:07:25
GPSalachs
Re: Deprecated features in the next version
Are the Calc_Essai and Macr_Recal command changes going to  be available with the next version of Code_Aster?
