#1 2019-12-07 02:02:41
kaengo
Installation on CentOS 8
Hello!
I tried once ago to install SalomeMeca 2019 on Centos 8
But I get:
[kaengo@kraehe salome_meca]$ export PATH=/usr/bin:$PATH
[kaengo@kraehe salome_meca]$ alias python=/usr/bin/python2.7
[kaengo@kraehe salome_meca]$ unset PYTHONPATH
[kaengo@kraehe salome_meca]$ export PYTHONHOME=/usr
[kaengo@kraehe salome_meca]$ ./salome_meca-2019.0.1-2-LGPL.run
[kaengo@kraehe salome_meca]$ python --version
Python 2.7.15
Self Extracting salome_meca V2019_univ Installer
Enter the salome_meca install directory [default=/home/kaengo/salome_meca] :
salome_meca is in English, do you want to be in French ? [y/N] :
Installation of salome_meca V2019_univ in /home/kaengo/salome_meca/V2019_univ ...
All good.
Done
Creating salome_meca application in /home/kaengo/salome_meca/appli_V2019_univ ...
Setting for help already set
./create_appli.sh: line 263: python: command not found
Warning: the directory /home/kaengo/.local/bin is in a path variable but does not exist
Warning: the directory /home/kaengo/bin is in a path variable but does not exist
To run the application:
$ /home/kaengo/salome_meca/appli_V2019_univ/salome
Adjusting wishexecutable /home/kaengo/salome_meca/V2019_univ/tools/Code_aster_frontend-20190/etc/codeaster/profile.sh
Final configuration
I reinstalled python 2 and tried again before this run.
Does anyone know the solution?
Greetings,
Holger
Edit:
I tried once ago the actual fedora 31 distro (in vmware).
Same failure ....
#2 2020-01-26 16:53:38
virengos
Re: Installation on CentOS 8
Dear code_aster experts,
I'm a happy Salome 9.3 / 9.4 user on Ubuntu and Fedora, now it's time to get familiar with code_aster.
In the last few weeks, I tried to install Salome Meca 2017-2019 on fresh installed Fedora 31 and CentOS 7.7/8.1 Linux distros. Unfortunately without success. Always the same known errors, as already reported by other users here.
I'm not the greatest Linux guru. But after some years of experience, I'm less or more familiar with the standard issues, debugging and troubleshooting.
Is it possible to get some more detailed info about the Linux distros and the Salome software has been developed and tested?
Distro / release number Linux, Salome, code aster / configuration / ~hardware ?
I'm feeling really motivated to run more checks and sharing my knowledge with the community.
Damian
