#1 2019-11-17 17:37:58
Giamma1997
Trouble seeing values from tables using IMPR_TABLE
I am using the post releve T in order to have a table showing the strain values of my model. Then I am printing them using IMPR_TABLE. The problem is when opening the file, some of the columns are over others and not one after anther one, so is a little hard to see the values of strain for each node. This is are the two commands on my command file and I have attached the table for the strain. Thank you for the help!
table2 = POST_RELEVE_T(ACTION=(_F(GROUP_NO=('N1', ),
                                  INTITULE='node1',
                                  NOM_CHAM='EPSI_ELNO',
                                  OPERATION=('EXTRACTION', ),
                                  RESULTAT=finalmoy,
                                  TOUT_CMP='OUI',
                                  TOUT_ORDRE='OUI'),
                               _F(GROUP_NO=('N2', ),
                                  INTITULE='node2',
                                  RESULTAT=finalmoy,
                                  TOUT_CMP='OUI',
                                  TOUT_ORDRE='OUI'),
                               _F(GROUP_NO=('N3', ),
                                  INTITULE='node3',
                                  RESULTAT=finalmoy,
                                  TOUT_CMP='OUI',
                                  TOUT_ORDRE='OUI'),
                               _F(GROUP_NO=('N4', ),
                                  INTITULE='node4',
IMPR_TABLE(FORMAT='TABLEAU',
           TABLE=table2,
           UNITE=4)
#2 2019-11-17 21:56:15
Re: Trouble seeing values from tables using IMPR_TABLE
It's OK for me ???
