#1 2019-10-24 13:42:45
brunajusto
Mass point
Good morning!
I would like to know how to add a mass point to a geometry.
thank you.
#2 2019-10-31 09:19:08
dezsit
Re: Mass point
you have to create 0D elements (POI in aster) on the nodes, where you want to apply mass element, then use DISCRETE element modelisation on these 0D elements. (more keywords: AFFE_MODELE->DIS_T, AFFE_CARA_ELEM->DISCRETE->M_T_D_N)
Check Jean Pierre Aubry's excellent book: framabook.org/beginning-with-code_aster/, eg. you will find an example on the 31.page.
BR
dezsit
#3 2019-11-01 13:55:46
brunajusto
Re: Mass point
Good morning dezsit,
Thank you for the help. I followed your tips but there is an error that I can't solve. See the error bellow and help me again if you can.
Thank you again.
#4 2019-11-01 17:09:53
Re: Mass point
without knowing the time this error arises it is impossibleo give any advice
please post the fumm message file
#5 2019-11-01 18:51:24
brunajusto
Re: Mass point
This is the hole massage that appears
#6 2019-11-02 08:46:45
Re: Mass point
                     CREA_GROUP_MA=_F(NOM='TOUT',
                                      GROUP_MA='Steel_SOLID',
                                      TYPE_MAILLE='POI1',
in the above code if you replace GROUP_MA by GROUP_NO you will create a POI1 on ALL the node belonging to 'Steel_SOLID'
if you want to create a POI1 on one node you have to create a group on this node in the mesh before hand
NOM='TOUT' is not very clever
#7 2019-11-04 18:15:54
brunajusto
Re: Mass point
I tried to do what you said and a new error appeared. It looks like my POI is included in another mesh.
It calculates the frequencies but does not consider the mass point.
#8 2019-11-04 21:49:02
dezsit
Re: Mass point
you defined the DIS_T in separate modelisation (model0) which is not used at all.
You have to define everything in the same model, what you want to use in an analysis, eg:
  model = AFFE_MODELE(MAILLAGE=mesh,
                      AFFE=(_F(PHENOMENE='MECANIQUE',
                              TOUT='OUI',
                              MODELISATION=('3D', ),),
                               GROUP_MA='0D',
                               MODELISATION=('DIS_T', ),),),
                      INFO=1,
                      VERI_JACOBIEN='OUI',
                      DISTRIBUTION=_F(PARTITIONNEUR='METIS',
                                      METHODE='SOUS_DOMAINE',),
BR
dezsit
#9 2019-11-05 08:52:10
Re: Mass point
right deszit
that is it
+ a few other mistakes
#10 2019-11-06 22:33:19
brunajusto
Re: Mass point
thanks again,
I ran the code aster analysis following your steps and got the frequencies. However, when I ran ansys the frequencies gave very different values. What could have happened in code aster?
Just remembering, I want to add a mass point and distribute it on a face or edge.
Sorry for my ignorance, I'm having difficulties with language.
Bruna Justo
#11 2019-11-07 08:00:14
Re: Mass point
the run looks like ok
the error is somewhere else
we need the mesh to understand and the values calculated by ansys
#12 2019-11-12 13:42:39
brunajusto
Re: Mass point
Good Morning,
I can't send the mesh file, but I'm sending some images, hope it helps.
thanks.
#13 2019-11-12 13:44:57
brunajusto
Re: Mass point
more information about the mesh.
I used NATGEN 1D-2D-3D
