#1 2019-10-30 03:53:29
Mahions
How to connect different meshes?
I have a complicated model which is simplified into beam, shell and solid.  The solid is divided into two parts(solid1、2), for I can’t mesh the solid into hexahedral grids at once.  It turns out that there are four meshes, mesh1(beam),mesh2(shell), mesh3(solid1),mesh4(solid2). When I read all meshes in AsterStudy , I assemble all the meshes by SUPERPOSE in ASSE_MAILLAGE, and use LIAISON_MAIL and LIAISON_ELEM to bind the DOF between mesh3\4 and mesh 1\2,2\3. Is that right?
