#1 2019-10-18 00:09:36
Humberto
Salome Meca 2019.0.0-1 Will not run in Debian 10 (Buster)
Have been using code-aster with no problems in several past versions but this one gives me this error:
Searching /Kernel/Session in Naming Service  +SALOME_Session_Server: /opt/salome_meca/V2019_univ/prerequisites/debianForSalome/lib/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /lib/x86_64-linux-gnu/libGLU.so.1)
SALOME_Session_Server: /opt/salome_meca/V2019_univ/prerequisites/debianForSalome/lib/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /lib/x86_64-linux-gnu/libQt5Xml.so.5)
And then the whole thing crashes.
Any ideas?
#2 2019-10-20 19:43:43
jkupka84
Re: Salome Meca 2019.0.0-1 Will not run in Debian 10 (Buster)
try to remove library libstdc++ from folder /opt/salome_meca/V2019_univ/prerequisites/debianForSalome/lib/
Best regards
JK
#3 2019-10-22 18:30:04
Humberto
jkupka84 wrote:
Best regards
JK
Thank you so much, it works now. Only that now the splash screen shows Version 2018.0.1
Is this correct? I thought I installed 2019
#4 2019-10-22 19:19:21
GXA_William
Greetings Humberto.
There is a new download for SMECA, just released this past Saturday.  The splash screen is correct on the latest download.
-William
