#1 2019-10-04 10:43:52
code_aster 14.4 on opensuse leap15.1 all good
i have just installed code_aster 14.4 on opensuse leap15.1
all good
except i had to create  a symlink libpython3.6.so pointing to libpython3.so
i ran an existing simple problem on astk
all good
all my best to the code_aster team
just one little thing
it would be good to have in the doc
python3 setup.py
instead of
python setup.py
#2 2019-10-18 10:35:04
Re: code_aster 14.4 on opensuse leap15.1 all good
hello mr. Aubry,
could you please provide your log and dbg file? I have the same system and my compilation fault with some kind of encodingerror.
<DBG> [8122/8126] Compiling catalo
<DBG> [8123/8126] Compiling data/profile.sh.tmpl
<DBG> Waf: Leaving directory `/tmp/install_aster.15895/aster-14.4.0/build/std/release'
<DBG> EXIT_COMMAND_15895_00000081=1
<DBG> +++ STANDARD ERROR: Build failed
<DBG> Traceback (most recent call last):
<DBG>  File "/tmp/install_aster.15895/aster-14.4.0/.waf3-2.0.12-842c5bf2f993e0c1b0fa93868c080b69/waflib/Task.py", line 176, in process
<DBG>    ret=self.run()
<DBG>  File "/tmp/install_aster.15895/aster-14.4.0/.waf3-2.0.12-842c5bf2f993e0c1b0fa93868c080b69/waflib/TaskGen.py", line 401, in run
<DBG>    self.outputs[0].write(code,encoding=getattr(self.generator,'encoding','latin-1'))
<DBG>  File "/tmp/install_aster.15895/aster-14.4.0/.waf3-2.0.12-842c5bf2f993e0c1b0fa93868c080b69/waflib/Node.py", line 108, in write
<DBG>    Utils.writef(self.abspath(),data,flags,encoding)
<DBG>  File "/tmp/install_aster.15895/aster-14.4.0/.waf3-2.0.12-842c5bf2f993e0c1b0fa93868c080b69/waflib/Utils.py", line 153, in writef
<DBG>    data=data.encode(encoding)
<DBG> UnicodeEncodeError: 'latin-1' codec can't encode character '\u017e' in position 1059: ordinal not in range(256)
<DBG>
<DBG> +++ END
 *** Exception raised : error during compilation
thank you
