#1 2019-10-16 02:49:24
nirmaljoshi
[solved] reading rmed file for post processing
Which command should i use to read result.rmed file (created after very long processing time) so that i can post process it (CALC_CHAMP) without re-running the analysis. In the previous analysis i forgot to calculate SIGM_ELNO and the hdf file has broken. I only have the mesh file and "rmed", the result file.
The CREA_RESU has no option to read external files.
Please help.
#2 2019-10-16 19:05:41
Re: [solved] reading rmed file for post processing
I suppose you may add another stage (in AsterStudy) and use POURSUITE instead of Debut. There are examples discussed in the 2nd edition of Aubry's book, with reference to astk.
Hope this helps.
Regards.
#3 2019-10-17 04:24:30
nirmaljoshi
Thanks. I could do the calculation.
For completeness, i post here the steps.
#1. Read the old result.rmed file by LIRE_MAILLAGE
#2. Use LIRE_RESU to result result variable (you should know the result variable)
#3. Define same material properties and assign to model and also while using CALC_CHAMP
                     UNITE=20)
                            TOUT='OUI'),
                    MAILLAGE=mesh)
steel = DEFI_MATER_GC(ACIER=_F(D_SIGM_EPSI=10000000000.0,
                               E=2e+11,
                               NU=0.3,
                               SY=400000000.0),
                      RHO=7850.0)
conMazMa = DEFI_MATERIAU(ELAS=_F(E=37303280300.0,
                                 NU=0.2,
                                 RHO=2400.0),
                         MAZARS=_F(AC=1.26865552,
                                   AT=0.9,
                                   BC=1681.54688,
                                   BT=12688.1906,
                                   EPSD0=7.88134441e-05,
                                   K=0.7,
                                   SIGM_LIM=39000000.0))
fieldmat = AFFE_MATERIAU(AFFE=(_F(GROUP_MA=('group_concrete', ),
                                  MATER=(conMazMa, )),
                               _F(GROUP_MA=('group_mainrebar', 'group_shearrebars'),
                                  MATER=(steel, ))),
                         MAILLAGE=mesh,
oldres = LIRE_RESU(FORMAT='MED',
                   FORMAT_MED=_F(NOM_CHAM='DEPL',
                                 NOM_RESU='resnonl0'),
                   TOUT_ORDRE='OUI',
                   TYPE_RESU='MODE_MECA',
                   UNITE=20)
stress = CALC_CHAMP(CHAM_MATER=fieldmat,
                    CONTRAINTE=('SIGM_ELNO', ),
                    DEFORMATION=('EPSI_ELNO', ),
                    RESULTAT=oldres)
IMPR_RESU(FORMAT='MED',
          RESU=_F(RESULTAT=stress),
          UNITE=80)
