#1 2019-10-14 10:52:39
Alessia Bez
How to add a nonlinear behaviour in STAT_NON_LINE analysis
Hello all,
I'm trying to model a material with non-linear elastic behavior with increasing stiffness for a static non linear analysis. I've tried several things but none of them work:
- DEFI_MATERIAU - TRACTION but since the stiffness increasing the software gives an error;
- I've defined a function with Young's modulus-EPSI trend, I've inserted it in ELAS_FO but it gives an interpolation error;
- I interpolated the constitutive law into a polynomial as a function of the deformations and defined it in FORMULE but the independent variable is not recognized
I would like to know if there is a possibility to insert a non-linear behavior with increasing stiffness.
Thank you in advance for sharing your knowledge
Alessia
#2 2019-10-14 21:04:42
Re: How to add a nonlinear behaviour in STAT_NON_LINE analysis
Elastic non-linear with increasing stiffness is ELAS_HYPER (hyperelastic material as Mooney-Rivlin, neo-hookean or Signorini model)
You cannot use TRACTION. It's only for (visco)-plastic material (generalized standard materials) with strain hardening
#3 2019-10-15 19:50:24
Alessia Bez
Thank you so much for your answer. You confirmed what I imagined, but is this the only way to consider non-linear elastic behavior? I would like to insert a constitutive law obtained from laboratory tests to describe the behavior of a particular material, do you think it is possible?
#4 2019-10-16 03:56:29
nirmaljoshi
For that case, you can define function for the material properties (copied from book by jean)
e.g.
s235elpl=DEFI_FONCTION(
NOM_PARA=’EPSI’ ,NOM_RESU=’SIGMA’ ,
VALE=(
#there should not be a point at 0.0, 0.0
#0.0000, 0.0
0 . 0 0 1 1 4 , 2 4 0 . 0 ,
0 . 0 0 1 2 , 2 4 1 . 0 ,
0 . 0 0 2 0 , 2 4 1 . 6 ,
0 . 0 0 5 0 , 2 4 4 . 0 ,
0 . 0 1 0 0 , 2 4 8 . 0 ,
0 . 0 1 5 0 , 2 5 2 . 0 ,
0 . 0 5 0 0 , 2 8 0 . 0 ,
0 . 1 0 0 0 , 3 2 0 . 0 ,
0 . 1 5 0 0 , 3 6 0 . 0 ,
0 . 2 0 0 0 , 3 8 0 . 0 ,
0 . 4 0 0 0 , 4 2 0 . 0 ,
INTERPOL=’LIN’ ,
PROL_DROITE=’LINEAIRE’ ,
PROL_GAUCHE=’CONSTANT’ ,
and define the material and apply it
steel=DEFI_MATERIAU(
ELAS=_F(E=210000 ,NU = 0 . 3 , ) ,
TRACTION=_F(SIGM=s235elpl , ) ,
mate=AFFE_MATERIAU(
MAILLAGE=mesh1 ,
AFFE=_F(TOUT=’OUI’ ,MATER=steel , ) ,
and perform analysis
resunl=STAT_NON_LINE(
MODELE=mod1 ,
CHAM_MATER=mate ,
EXCIT=(
_F(CHARGE=fix1 , ) ,
_F(CHARGE=load , TYPE_CHARGE=’FIXE_CSTE’ ,FONC_MULT=load_m , ) ,
COMPORTEMENT=_F(
RELATION=’VMIS_ISOT_TRAC’ , #U4.51.11 para 4.3.1.3
DEFORMATION=’SIMO_MIEHE’ , #U4.51.11 para 4.5.3
INCREMENT=_F(LIST_INST=linst , ) ,
NEWTON=_F(
PREDICTION=’TANGENTE’ ,
MATRICE=’TANGENTE’ ,
REAC_ITER=1 ,
CONVERGENCE=_F(RESI_GLOB_RELA=1e?4,ITER_GLOB_MAXI=3 0 0 , ) ,
#5 2019-10-16 07:29:30
Alessia Bez
I'm sorry because my answer was incomplete. The behavior of the material in question is infinitely elastic nonlinear, with Young's modulus increasing, so unfortunately using TRACTION the software signals an error. Thanks for your advice.
Alessia
