#1 2019-10-11 18:29:13
kathi
SalomeMeca2019 on Ubuntu 18.04
SalomeMeca 2019 does not start on my  Ubuntu 18.04. I did not find (or do not understand) the necessary help in this thread:
https://www    .code-aster.org/forum2/viewtopic.php?id=24476
So I post here the output in my shell. Can somebody please explain me what to do (I m not really expert with Linux)
Thank you
kathi
kathi@nero:/opt$ ./SaloMec2019/appli_V2019_univ/salome
runSalome running on nero
Searching for a free port for naming service: 2815 - OK
Searching Naming Service  + found in 0.1 seconds
Searching /Kernel/Session in Naming Service  +SALOME_Session_Server: /opt/SaloMec2019/V2019_univ/prerequisites/debianForSalome/lib/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/lib/x86_64-linux-gnu/libQt5Xml.so.5)
SALOME_Session_Server: /opt/SaloMec2019/V2019_univ/prerequisites/debianForSalome/lib/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/lib/x86_64-linux-gnu/libQt5OpenGL.so.5)
SALOME_Session_Server: /opt/SaloMec2019/V2019_univ/prerequisites/debianForSalome/lib/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/lib/x86_64-linux-gnu/libQt5PrintSupport.so.5)
SALOME_Session_Server: /opt/SaloMec2019/V2019_univ/prerequisites/debianForSalome/lib/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/lib/x86_64-linux-gnu/libQt5Test.so.5)
SALOME_Session_Server: /opt/SaloMec2019/V2019_univ/prerequisites/debianForSalome/lib/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/lib/x86_64-linux-gnu/libQt5Network.so.5)
SALOME_Session_Server: /opt/SaloMec2019/V2019_univ/prerequisites/debianForSalome/lib/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/lib/x86_64-linux-gnu/libQt5Help.so.5)
SALOME_Session_Server: /opt/SaloMec2019/V2019_univ/prerequisites/debianForSalome/lib/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/lib/x86_64-linux-gnu/libQt5Sql.so.5)
SALOME_Session_Server: /opt/SaloMec2019/V2019_univ/prerequisites/debianForSalome/lib/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5)
SALOME_Session_Server: /opt/SaloMec2019/V2019_univ/prerequisites/debianForSalome/lib/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5)
SALOME_Session_Server: /opt/SaloMec2019/V2019_univ/prerequisites/debianForSalome/lib/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/lib/x86_64-linux-gnu/libQt5Core.so.5)
SALOME_Session_Server: /opt/SaloMec2019/V2019_univ/prerequisites/debianForSalome/lib/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/lib/x86_64-linux-gnu/libQt5Svg.so.5)
SALOME_Session_Server: /opt/SaloMec2019/V2019_univ/prerequisites/debianForSalome/lib/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/lib/x86_64-linux-gnu/libQt5Concurrent.so.5)
  File "/opt/SaloMec2019/V2019_univ/modules/KERNEL_V9_3_0/bin/salome/orbmodule.py", line 172, in waitNSPID
    os.kill(thePID,0)
ProcessLookupError: [Errno 3] No such process
During handling of the above exception, another exception occurred:
  File "/opt/SaloMec2019/appli_V2019_univ/bin/salome/runSalome.py", line 633, in useSalome
  File "/opt/SaloMec2019/appli_V2019_univ/bin/salome/runSalome.py", line 578, in startSalome
  File "/opt/SaloMec2019/V2019_univ/modules/KERNEL_V9_3_0/bin/salome/orbmodule.py", line 174, in waitNSPID
RuntimeError: Process 77916 for /Kernel/Session not found
kathi@nero:/opt$
#2 2019-10-12 15:02:22
IV_CoAs
Re: SalomeMeca2019 on Ubuntu 18.04
Hello
”www.code-aster.org/V2/spip.php?article1076”
Follow this French speaking article. It has right instructions, maybe some parts should not be capital character, but apt-get install command will tell it.
Using these instructions my ubuntu 18.04 platform is working.
Br Ilkka
#3 2019-10-14 16:12:48
kathi
Dear IV_CoAs
thank you for this hint, I did so and it works now!!!
But there remains a dissatisfactation for me, I would be very happy to get help to understand that:
Due to ”www.code-aster.org/V2/spip.php?article1076” we have to install on Ubuntu 18.04 those packages:
Installer les paquets suivants :
libQt5OpenGL
libQt5Concurrent
libNLopt0
libQT5MultimediaWidgets (pour shaper)
But no one of the usual commands worked:
sudo apt-get install libQt5OpenGL
sudo apt-get install libQt5Concurrent
sudo apt-get install libNLopt0
sudo apt-get install libQT5MultimediaWidgets
For each of the package names I searched with google how to do, and I found commands like this:
sudo apt-get install libqt5opengl5-dev
(for libQt5OpenGL)
and so on. At the end it is like a "miracle" for me that it really works. I do not understand the logic and the systematicity of that stuff. And why do the maintainers of SalomeMeca not write "sudo apt-get install libqt5opengl5-dev" instead of "sudo apt-get install libQt5OpenGL"? I would really like to understand the systematic and logic way
Thank you in advance for helping me out of this question
kathi
#4 2019-10-14 21:10:30
Easy answer.
When I tried to install salome_meca on my Ubuntu, these commands has worked !
#5 2019-10-18 13:57:15
Hi Kathi
The following are the reasons:
1. In Linux world, most of the commands are case-sensitive
2. The apt-get install command looks in the ubuntu repository and it can install only if the name of the program (library etc.) is exactly same as that in the repository.
However, there is a way out to find the correct name to be supplied for installing a package/library etc.:
# Use the following in a terminal
 sudo apt search <search term>
where search term may contain mix of upper/lower case.
For example
 sudo apt search libQt5Multimedia
would produce something like the following
[sudo] password for sukumar:
Sorting... Done
Full Text Search... Done
libqt5multimedia5/bionic,now 5.9.5-0ubuntu1 amd64 [installed,automatic]
  Qt 5 Multimedia module
libqt5multimedia5-plugins/bionic 5.9.5-0ubuntu1 amd64
  Qt 5 Multimedia module plugins
libqt5multimediaquick-p5/bionic 5.9.5-0ubuntu1 amd64
  Qt 5 Multimedia Quick module
libqt5multimediawidgets5/bionic,now 5.9.5-0ubuntu1 amd64 [installed]
  Qt 5 Multimedia Widgets module
sukumar@sukumar-HP-200-G3-AiO:~$
Hope this helps.
Regards.
#6 2019-10-19 21:40:47
Humberto
Installing those libraries in Debian Buster **did not work**.
most have a 5 at the ending.
like libQt5Concurrent --- libqt5concurrent5
and so on.
#7 2019-10-19 23:12:58
kathi
thank you, SalomeMeca is now running and I have learnt a lot.
Specially  I got very clear learning this command "sudo apt search <search term> "
kathi
#8 2019-11-08 10:58:08
romduval
In my case, i was using CAELINUX 2018 (sur Xubuntu 16.04).
I had some problems  (qt5 et other) trying to install new version (the last version) of SalomeMeca.
Then I upgraded:
do-release-upgrade
18.04 has been upgraded.
I have deleted the previous folder /opt/SalomeMeca
Then followed website instructions:
>Installation
>Uncompress the file and launch the install:
>>tar xvf Salome-Meca-2017.0.2-LGPL-2.tgz && ./Salome-Meca-2017.0.2-LGPL-2.run
I installed SalomeMeca in tge suggested folder.
Then (note that this instruction is available in French version of the website)
>Instructions pour installer les prérequis nécessaires aux distributions anciennes
>Ubuntu 18.04 et plus
>La bibliothèque ’libstdc++.*’ installée par salome_meca entre en conflit avec celle du système.
>>cd $HOME/salome_meca/V2019_univ/prerequisites/debianForSalome/lib
>>rm libstdc++.so.6.0.20
>>ln -s /usr/lib/x86_64-linux-gnu/libstdc++.so.6 libstdc++.so.6.0.20
>Installer les paquets suivants : (ils étaient déjà installés sur mon poste)
>libQt5OpenGL
>libQt5Concurrent
>libNLopt0
Looks like evreything is working well on Xubuntu 18.04.
Hope this can help,
Romain DUVAL
CETIM
