I would like to compile MUMPS with MPI, and got the following error during configure with waf:
./waf configure --prefix=${PUBLICP}/mumps-${MUMPS_VER}_mpi --install-tests --enable-mpi --python=/usr/bin/python3
Setting top to : /opt/aster/public/build/mumps
Setting out to : /opt/aster/public/build/mumps/build
File "/opt/aster/public/build/mumps/.waf-1.8.22-5fa41dedfc4a80e01a7ca1d1c9d570c0/waflib/Scripting.py", line 114, in waf_entry_point
run_commands()
File "/opt/aster/public/build/mumps/.waf-1.8.22-5fa41dedfc4a80e01a7ca1d1c9d570c0/waflib/Scripting.py", line 175, in run_commands
ctx=run_command(cmd_name)
File "/opt/aster/public/build/mumps/.waf-1.8.22-5fa41dedfc4a80e01a7ca1d1c9d570c0/waflib/Scripting.py", line 166, in run_command
ctx.execute()
File "/opt/aster/public/build/mumps/.waf-1.8.22-5fa41dedfc4a80e01a7ca1d1c9d570c0/waflib/Configure.py", line 87, in execute
super(ConfigurationContext,self).execute()
File "/opt/aster/public/build/mumps/.waf-1.8.22-5fa41dedfc4a80e01a7ca1d1c9d570c0/waflib/Context.py", line 93, in execute
self.recurse([os.path.dirname(g_module.root_path)])
File "/opt/aster/public/build/mumps/.waf-1.8.22-5fa41dedfc4a80e01a7ca1d1c9d570c0/waflib/Context.py", line 134, in recurse
user_function(self)
File "/opt/aster/public/build/mumps/wscript", line 84, in configure
self.load('ext_aster', tooldir='waftools')
File "/opt/aster/public/build/mumps/.waf-1.8.22-5fa41dedfc4a80e01a7ca1d1c9d570c0/waflib/Configure.py", line 141, in load
module=Context.load_tool(tool,tooldir,ctx=self,with_sys_path=with_sys_path)
File "/opt/aster/public/build/mumps/.waf-1.8.22-5fa41dedfc4a80e01a7ca1d1c9d570c0/waflib/Context.py", line 370, in load_tool
__import__(tool)
File "waftools/ext_aster.py", line 31, in <module>
class fcprogram(fc.fcprogram):
File "/opt/aster/public/build/mumps/.waf-1.8.22-5fa41dedfc4a80e01a7ca1d1c9d570c0/waflib/Task.py", line 52, in __init__
(f,dvars)=compile_fun(cls.run_str,cls.shell)
File "/opt/aster/public/build/mumps/.waf-1.8.22-5fa41dedfc4a80e01a7ca1d1c9d570c0/waflib/Task.py", line 633, in compile_fun
return composed_fun,dvars
UnboundLocalError: local variable 'dvars' referenced before assignment
It might have a simple cause, but I am not able to figure it out.
(exporting INCLUDES and LIBPATH variables have been done).
It did not work with default python installation either (with 2.7 at this moment, so without --python=/usr/bin/python3).
(And actually it worked earlier, when I compiled with aster 13.6 on the same computer, so I probably installed some new software component meanwhile which can prevent the correct operation of waf...)
Any help would be highly appreciated.
BR.
dezsit
I had similar problems with waf, but I manage to compile it using brutal "Kekkosen konsti", which means,that:
1. I copied MUPS-5.1.1 (Aster 13.6) Makefile.inc
2. Change all paths to new paths in this file
3. make all
I manage to make parallel (mpi) mumps using this method; naturally it is not good permanent solution and I hope that somebody can give solution for waf 'dvars' problem.
BR
Ilkka
I solved the "UnboundLocalError: local variable 'dvars' referenced before assignment" problem
Replace all
./waf ...
calls by
python3 waf ...
By the way the Docker images (github.com/tianyikillua/code_aster_on_docker) will be soon updated to 14.4
Wow, python3 waf ... worked perfectly! Although, I struggled with compiling Mumps since Monday, with make and an own Makefile, and finally I succeed today morning, it is good to see a simple solution
Thanks both of you!
And many thanks tiany for the updated docker, we are using the old 13.6 MPI version very often!
BR
dezsit
