#1 2018-08-14 21:40:16
baranger
Aster-Study remote ERROR
I installed salomemeca 2018 on fedora 27 with success,
but I'm getting an error when trying to launch study and in the log file there is this message
"ERROR: The user login on remote machine MUST be given."
and the following errors appear in the terminal shell:
___________________
/bin/cp: impossible d'évaluer '/tmp/asterstudy_workdir_tbaranger/tbaranger-linux-2.home-mar.-14-221200.644/./Study1_res.med': Aucun fichier ou dossier de ce type
/bin/cp: impossible d'évaluer '/tmp/asterstudy_workdir_tbaranger/tbaranger-linux-2.home-mar.-14-221200.644/./message': Aucun fichier ou dossier de ce type
/bin/cp: impossible d'évaluer '/tmp/asterstudy_workdir_tbaranger/tbaranger-linux-2.home-mar.-14-221200.644/./base-stage1': Aucun fichier ou dossier de ce type
____________________________
Could any one help ? Thanks.
#2 2018-08-15 19:15:16
baranger
Re: Aster-Study remote ERROR
Issue solved by fixing hostname and the associated ssh key
Best regards
#3 2019-06-24 08:59:45
hendrius
Thank you for the tip. I got it solved just by changing my hostname.
#4 2019-07-16 23:08:13
cada
Hi, what exactly have you done please? Got exactly the same issue.
Running on Fedora 30
#5 2019-07-17 12:24:18
cada
So for some reason just renaming hostname to my username does the trick
hostname cada
Why does it need a hostname in a first place? (running salome on a local machine)
#6 2019-07-17 13:34:10
what means 'ntb'?
#7 2019-07-17 15:55:24
even a local machine Salome runs in a client server manner
client and server are on the same machine
it works on the loopback IP-Address (usually 127.0.0.x)
but you have to give the name of the server (or localhost)
all this is set in /etc/hosts
this is basic networking with linux
#8 2019-09-15 08:40:22
serge
Jean-Pierre is wright ... but it's not so trivial for everybody !
I got this error message on my "Mageia-7" up-to-date station. Then, google shows questions about debian and fedora machines Aster Study launch login error ...
Discussions about copying /tmp files  to filesystem was "absurd" as /tmp is 7777, ssh to localhost is "useless" and, at last hostname solution worked ... but was incomplete.
I found that "RTFM" is, once more the best solution ! so ... read it:
$ man hostname
THE FQDN :
... this paragraph is very precise about "hostname" use.
... lower, the use of /etc/hostname file is clearly indicated
FILES :
/etc/hostname  Historically  this  file  was  supposed to only contain the hostname and not the full
canonical FQDN
. Nowadays most software is able to cope with a full FQDN here. This file is  read  at
boot time by the system initialization scripts to set the hostname.
Not so trivial but simple:
      "Aster study" does not cope with  "ursula.example.com" and prefers "ursula"
... eventually, it's up to you to route "127.0.0.1    ursula.example.com ursula" in your /etc/hosts file ...
$ hostnamectl permit to check if your 'Static hostname' is only simple "ursula" and NOT the FQDN.
(personally, I changed "darkstar.obs-local" to simple "darkstar" in /etc/hostname file.)
$ man hostnamectl ... will make you an "HOSTNAME Guru"
Best regards and thanks to CodeAster people, the Study GUI is "magnifique" !
Serge.
     Serge Montagnac
http://www.obs-psr.com
#9 2019-10-02 06:23:24
saad
Best regards
Could you explain how to do this. I am running into the exact same issue.
#10 2019-10-02 06:44:45
saad
Stay blessed
Regards Saad
#11 2020-01-05 08:11:15
Surprisingly this did the trick for me too!
I changed HOSTNAME from localhost to my USERNAME and SM is working. This is unexpected. Can someone elaborate on this?
