#1 2019-09-02 10:20:26
nirmaljoshi
varying E with time using ELAS_FO
Could you please help me for the following task.
I have to model a concrete prism whose elasticity(E) decreases with time (0 to 365 days). I want to calculate displacement with respect to time for a constant load.
Using the method mentioned in the posts at forum2/viewtopic.php?id=24091 and forum2/viewtopic.php?id=20431, I wrote my analysis file. It runs, but there is no evolution of E with time- resulting in constant deformation for all the time steps.
What am I missing? Please help. File is attached.
#2 2019-09-03 05:54:30
nirmaljoshi
Re: varying E with time using ELAS_FO
It seems in CREA_CHAMP (AFFE=_F(.. VALE=(365)) is causing the calculation to give constant displacement.  When I try to use VALE_F=somefunction, it gives error saying "inconsistency between component count and many values".
So is there any way to change the time within CREA_CHAMP or CREA_RESU?
#3 2019-09-03 15:06:33
manonB
When you created your field using the VALE_F with your function, did you use the ELNO_NEUT_F field?
You usually get this error if you use ELNO_NEUT_R.
Manon
#4 2019-09-04 04:34:35
nirmaljoshi
Dear Manon,
Thanks for pointing towards correct direction.
Using ELNO_NEUT_F field prevented that error. But now i get error saying "only the fields of functions to the nodes are appraisable: CHAMP_ELEM_NEUT_F" while i invoke CREA_RESU using the field created by the CREA_CHAMP.
When I use NOEU_NEUT_F, the error disappears, but again, there is no effect on the elasticity and i get constant displacement (file attached).
I am stucked!
