Dear all,
I wondered if it is possible to define an isotropic material with Tri-Linear elasticity: Modulus Young (E_Young) depends on volumetric deformation like that:
E_F=DEFI_FONCTION(
NOM_PARA='EPSI', #'DIVU'
VALE=(0.015,100e6,
0.515,5.825e6,
0.585,100e6 ),
PROL_DROITE='CONSTANT',
PROL_GAUCHE='CONSTANT',);
However, there is the error attached, which I don't understand.
! <S> Exception user raised but not interceptee. !
! The bases are fermees. !
! Type of the exception: error !
! Erreur lors de l'interpolation de la fonction E_F sur la maille M61, il manque !
! le paramètre EPSI
Could anyone help me please?
Thank you and best regards,
Phoenix TRAN,
I also modify with a loop for each iteration to obtain DIVU (or EPSI=EPSIxx+EPSIyy+EPSIzz) from the last calculation, but it has the same error.
How to obtain the DIVU for an interpolation?
About informations I'm very happy.
TRAN,
Hi, I think E an NU can't be a function of EPSI, only X, Y, Z and INST.
I would check the material model...
Kind regards Volker
Thank you Volker,
On the last page of the document U4.43.03: E_F = DEFI_FONCTION(NOM_PARA='NEUT1'....
that means E can illustrate as a function of NEUT1...
On the document U4.31.02 (DEFI_FONCTION): NOM_PARA can be 'EPSI'
On the document U2.04.05 (on page 34):
MATEHY=AFFE_MATERIAU(MAILLAGE=MAIL, AFFE=_F(TOUT='OUI', MATER=MATERIAU,),
AFFE_VARC=_F(NOM_VARC='DIVU', EVOL=DEFVHY,),);
I am not good at T.H.M model so I don't know how to use this NOM_VARC='DIVU' (as they did) in my modeling (just mechanical problem).
Any recommendations will be appreciated!
Kind regards Tran,
Kind regards Volker
Hi Tran,
Maybe this topic can help you. It shows how to apply a field into the nodes using "NOM_VARC":
/viewtopic.php?id=17518
In particular:
CHAM_GEO=CREA_CHAMP(TYPE_CHAM='NOEU_GEOM_R', # Create the field of the geometrical coordinates
OPERATION='EXTR',
MAILLAGE=MAIL,
NOM_CHAM='GEOMETRIE',);
YOUNG_Y = FORMULE(VALE='3.0E6*Y', # Create a function of youngs modulus depending on Y-coordinate
NOM_PARA='Y',);
CH_FONC=CREA_CHAMP(TYPE_CHAM='NOEU_NEUT_F', # Create a field of functions (YOUNG_Y) per node
OPERATION='AFFE',
MAILLAGE=MAIL,
AFFE=_F(
TOUT='OUI',
NOM_CMP='X1',
VALE_F=YOUNG_Y,),);
CHYOUNG=CREA_CHAMP(TYPE_CHAM='NOEU_NEUT_R', # Evaluate the field CH_FONC with parameter field CHAM_GEO at each node
OPERATION='EVAL',
CHAM_F=CH_FONC,
CHAM_PARA=CHAM_GEO,);
# Now you should have a field representing the youngs modulus at each node
# the rest is described in U3.43.03
NU_F=DEFI_CONSTANTE (VALE=0.3);
E_F = DEFI_FONCTION (NOM_PARA='NEUT1',
VALE= (-1.E-9, -1.E-9,
1.E+9, 1.E+9));
MA=DEFI_MATERIAU (ELAS_FO=_F (E=E_F, NU=NU_F,),);
CM=AFFE_MATERIAU (MAILLAGE=M,
AFFE=_F (TOUT= OUI, MATER= MA),
AFFE_VARC=_F (NOM_VARC='NEUT1', CHAMP_GD=CHYOUNG),
However, I must admit I've never used EPSI as function parameter.
I hope it can be useful,
Joan
Hi joanBO,
It's really so good to see your reply.
However, I still do not know how to use "NOM_VARC" as you said, I think that may be suitable only in the case of E = Function(Coord).
I found a similar topic on /viewtopic.php?id=13791
Then I do not know how to use the function of Sigma=f(EPSI) into DEFI_MATERIAU as Mr. Jmp mentioned as below
# FT1 is the final curve, ready to use in DEFI_MATERIAU
FT1=RECU_FONCTION(TABLE=T1,PARA_X='EPSI',PARA_Y='SIGM')
I am trying to make the loop for the E_Young as a function of EPSI by manual Python scripts.
It is so complicated because each step needs to be checked the convergence of Epsi, and if does not meet the pre-selection then this step must be updated the LIST_INST, the input parameters, so forth.
Regards, Tran.
