#1 2019-04-30 15:37:38
pironman
Time set after running simulation
When I run a simulation, appear a window where I can set the value of RAM and the time.
I see that the time is limited to 23:59:59, and that's a problem! I need to simulate a very complex dynamic structure, and the entire simulation take more than 24 hour.
How can I impose a bigger time?
#2 2019-05-01 08:01:09
Re: Time set after running simulation
I asked the same question in 2017:
https://code-aster.org/forum2/viewtopic.php?id=23106
This issue is solved in the 2018 version.
#3 2019-05-03 09:13:42
pironman
Thank you!
