#1 2019-01-15 15:35:14
GPSalachs
[SOLVED]Salome Meca 2018 Freeze problems
Hello all,
i have installed the latest Salome Meca 2018. I have read some work arounds that exist in the forums for some of the problems it causes for people,
me included. My latest problem is that it freezes a lot when a study is run. It doesn't show the study running at all and it takes forever to save it.
Have you also encountered this problem? How did you work around it?
#2 2019-01-23 19:16:17
runrun
Re: [SOLVED]Salome Meca 2018 Freeze problems
I had the same problem during a non-linear analysis, on salome-meca 2018 working on ubuntu 16. After a few steps (almost 35 on 50) with 5/200 iterations each, the new bash just freeze. I waited and I have to say that the analysis arrive at the end (green botton) but after a loooooot of time. I checked if during the freezing time aster study is still working and it seems that the process is still going on (checking writing ''top'' in the terminal).
Thanks to all who may help me and the rest of the community!
#3 2019-02-14 09:57:22
GPSalachs
Sorry to ask but did you find a solution about the freeze ? I have tried to uninstall and reinstall everything but the problem continues.
#4 2019-02-15 09:17:08
RebeccaWallace
I'm having serious trouble with ParaVis. It is almost impossible to start up this module successfully. I get a message saying “SIGSEGV 'segmentation violation' detected. Address 7f2619447830”. Then Salome-Meca freeze completely. The other modules (GEOM, MESH, etc.) run properly.
My OS is Debian 8.
[URL=https://urdu.arynews.tv/]Urdu News[/URL]
#5 2019-03-19 12:40:01
GPSalachs
are there any news on the gui freezing ?!
Is it a graphic card problem?HDD problem?
The main issue for me is that 3/10 times it works fine i can see the calculations and 7/10 it freezes as in the screenshot.
I noticed that even if the calculation runs in the background, it takes at least double the time to finish.
