#1 2018-08-23 12:23:41
aitalaini
mazars problem
Dear all,
I'm trying to use the  mazars model to reproduce a real experiment on mansory, but i have a lot of problem converging that.
I tried all stuff i found on th forum but i have the same problem.
I would like to ask you what is the error i made,
thanks
#2 2018-09-04 12:57:36
jlf
Re: mazars problem
Not easy to help you. Could you give us, at least, the values of alls the parameters you use?
JLF
#3 2018-09-09 22:08:11
aitalaini
Re: mazars problem
sorry i forget the attachment
#4 2018-09-14 08:37:33
jlf
Re: mazars problem
It's bizarre.
With only the gravity load, you produce the rupture of the concrete !!
To see the gravity effect, you can create a linear function to apply this load.
Could you check your units and loads values ?
JLF
#5 2018-09-15 15:08:59
aitalaini
Re: mazars problem
thanks jlf, the parameter RHO was out of scale, but also with correct unit don't converge.
If you know parameters of mazars  are dimensionless?
#6 2018-09-24 08:52:34
jlf
Re: mazars problem
yes, the mazars parameters are dimensionless.
BUT you must have the correct unit for your problem. For example m, N, Pa.
Your Young modulus is 1000, for concrete is 32000MPa or 32000E+06Pa.
Did you plot the mazars behavior for unidimensional traction and compression with your parameters ?
With your values, if Young modulus is in MPa the max stress in compression is 0.33MPa.
JLF
#7 2018-09-27 10:45:18
aitalaini
Re: mazars problem
theoretically unit of my model is mm, for test on mansory wall. I see some example, but i not understand what i do wrong.
#8 2018-09-27 12:17:27
Re: mazars problem
try these more reasonable parameters
E=32000 as suggested by jlf
Bc=1000 as suggested by jlf and in U4.43.01 document
RESI_GLOB_RELA=0.0015
or a PAS varying along time
and Introduce yourself in the relevant section of the forum
#9 2019-06-20 10:07:42
95ims
Re: mazars problem
Did you find a solution to the convergence issue? I am having the same problem with Mazars.
Thanks.
#10 2019-06-20 11:29:33
nirmaljoshi
Re: mazars problem
Here is worksheet to calculate mazars parameter by yourself.
Also you can use DEFI_MATER_GC so that you do not need to input each parameters.
#11 2019-06-20 11:31:01
nirmaljoshi
Re: mazars problem
jlf wrote:
JLF
How do we do that? Can you provide simple example.
