#1 2018-07-24 14:55:59
trouble to build the unstable version
trying to build the unstable version with waf
i get the following error at Configuration of the source repository stage
dedalus@dedalus:~/dev/codeaster> $HOME/dev/codeaster/devtools/bin/install_env --internet
Unknown repository in '/home/dedalus/dev/codeaster'
Please provide repository path as argument (see 'install_env --help').
what can be done ?
#2 2018-07-24 15:21:14
Re: trouble to build the unstable version
once the command is [corrected?] with the proper path?
i get
dedalus@dedalus:~/dev/codeaster/devtools>  $HOME/dev/codeaster/devtools/bin/install_env   --internet
  File "/home/dedalus/dev/codeaster/devtools/bin/install_env", line 654, in <module>
    repocfg = RepoCfg.factory(repodir, internet=opts.noedf, builder=builder)
  File "/home/dedalus/dev/codeaster/devtools/bin/install_env", line 200, in factory
    assert config.astersrc, "Only supported for codeaster repositories."
AssertionError: Only supported for codeaster repositories.
this is fully not understanble!!
#3 2018-07-24 23:26:22
Hello Jean-Pierre,
the install_env script should be applied to a code_aster source repository (e.g. « src »).
« devtools » is not a code_aster source repository.
#4 2018-07-25 07:42:04
hello Thomas
i understand i have to do that
still an error
dedalus@dedalus:~/dev/codeaster> $HOME/dev/codeaster/devtools/bin/install_env  $HOME/dev/codeaster/src --internet
Configuring 'src' repository...
INFO     checking repository /home/dedalus/dev/codeaster/src
INFO     settings added into /home/dedalus/dev/codeaster/src/.hg/hgrc
INFO     checking repository /home/dedalus/dev/codeaster/data
INFO     checking repository /home/dedalus/dev/codeaster/validation
INFO     checking repository /home/dedalus/dev/codeaster/devtools
  File "/home/dedalus/dev/codeaster/devtools/bin/install_env", line 689, in <module>
    reset=opts.reset, integration=opts.integration)
  File "/home/dedalus/dev/codeaster/devtools/bin/install_env", line 426, in main
    subcfg = RepoCfg.factory(osp.join(rootdir, repo), repocfg.internet)
#5 2018-07-28 16:26:21
Hello Jean-Pierre,
Argh, did you update the devtools repository before trying install_env?
cd $HOME/dev/codeaster/devtools
hg pull -u
#6 2018-08-24 07:03:17
mathieu.courtois
This is a regression in devtools that is now fixed and will be available very soon.
MC
