#1 2018-08-08 16:48:11
praful
[SolvED] Error in Rectangular section of POUTRE under AFFE_CARA_ELEM
I am trying to use rectangular section under POUTRE of AFFE_CARA_ELEM but gets an error as shown in attached pic
Prafulla Malla
#2 2018-08-09 07:37:36
Re: [SolvED] Error in Rectangular section of POUTRE under AFFE_CARA_ELEM
it looks like
GROUP_MA=
is missing to tell to code_aster on which element to apply the given section
#3 2018-08-09 10:23:53
praful
I have selected the GROUP_MA. A new picture
Prafulla Malla
#4 2018-08-09 14:42:32
i do know what is the problem
i use only code_aster stand alone
and i write the .comm file with a text editor
it seems so much simpler to me!
#5 2018-08-10 05:56:39
praful
yeah, it worked through the standalone but I do not know what happened in the graphical version. You are the guru , so you can write .comm file in text editor. I need more practise smile
Prafulla Malla
#6 2018-08-10 09:25:10
I tried on Salome_Meca 2018 , but I had no problem (no error)
I don't understand
#7 2018-08-11 13:41:02
That bug happens only in the Windows version.
#8 2018-08-11 14:09:16
+1
Its a windows version specific issue.
It is highly recommended to use either docker image or CAELinux Live CD if you are not willing to give up on windows yet.
#9 2018-08-11 15:28:35
praful
Yeah, you are right, it was in windows version. After, that I tried in linux, same code worked perfectly.
Prafulla Malla
