#1 2017-05-30 10:07:18
Msegade
[Solved] Buckling loads of a shell
Hi
So I'm continue analyzing the shell that I discussed in the post: Distribute a load to a set of nodes (Sorry I cannot post links).
Now I'm trying to do a buckling analysis wich I do with these steps:
# Resolution
res1=MECA_STATIQUE(  MODELE=modl,
                     CHAM_MATER=chmat,
                     CARA_ELEM=cara,
                     EXCIT=(
                                    _F( CHARGE = rdisp),
                                    _F( CHARGE = clim),
                                    _F( CHARGE = press),
                                    _F( CHARGE = pload),),
                    OPTION = 'SIEF_ELGA',
# Stress field to calculate the geometric stiffnes matrix
stressg = CREA_CHAMP (
                      RESULTAT = res1,
                      OPERATION = 'EXTR',
                      TYPE_CHAM = 'ELGA_SIEF_R',
                      NOM_CHAM = 'SIEF_ELGA',
                      TYPE_MAXI = 'MINI',
                      TYPE_RESU = 'VALE'
# Elementary matrices and Assembly
matg = CALC_MATR_ELEM (OPTION = 'RIGI_GEOM',
                            MODELE = modl,
                            CARA_ELEM = cara,
                            SIEF_ELGA = stressg,)
matm = CALC_MATR_ELEM (OPTION = 'RIGI_MECA',
                          MODELE = modl,
                          CHAM_MATER = chmat,
                          CARA_ELEM = cara,
                          CHARGE = (rdisp, clim,
                                    #press, pload,
nuddl = NUME_DDL (MATR_RIGI = matm,)
masrig = ASSE_MATRICE (MATR_ELEM = matg,
                         NUME_DDL = nuddl,)
masrim = ASSE_MATRICE (MATR_ELEM = matm,
                         NUME_DDL = nuddl,)
# Calculate the modes
modp1 = CALC_MODES (MATR_RIGI_GEOM = masrig,
                    OPTION = 'PLUS_PETITE',
                    MATR_RIGI = masrim,
                    SOLVEUR_MODAL  =
                        _F(
                            METHODE='SORENSEN'
                    TYPE_RESU = 'MODE_FLAMB',
                    CALC_CHAR_CRIT = _F(
                            NMAX_CHAR_CRIT = 6,
I get very low values for the critical load
numéro    charge critique    norme d'erreur
    1       2.37993E-02        1.35091E-10
    2       2.37993E-02        1.43175E-10
    3       2.43823E-02        1.52333E-10
    4       2.43823E-02        1.21724E-10
    5       2.64413E-02        9.63314E-11
    6       2.64413E-02        1.12501E-10
and the modes are global
As in the other post I'm comparing the results with the ones I get using abaqus, where I get much bigger critical load:
MODE NO      EIGENVALUE
       1      0.51168
       2      0.53620
       3      0.54860
       4      0.55567
       5      0.56876
       6      0.57455
and the modes are local which correspond to the location of maximun compression values, that makes more sense than the
global modes:
The rest of results (displacements, stresses...) of the linear static analysis, I get the same values in code_aster and abaqus.
What can I do to solve this?
I attach the .comm and .med file.
Thanks.
#2 2017-05-30 15:05:08
Re: [Solved] Buckling loads of a shell
what is the variable load upon which buckling is to be calculated
this is not very clear in your example
jeean pierre aubry
#3 2017-05-30 22:43:37
Msegade
jeanpierreaubry wrote:
jeean pierre aubry
Are both the "pload" and "press" loads.
#4 2017-05-31 05:48:58
do you mean they vary linealy TOGETHER at the same rate ?
#5 2017-05-31 08:09:18
Msegade
Yes, later I would want to make another analysis where I  just vary one of the loads while remaining the other costant,
but the results I got in abaqus are with both loads varying linealy together at the same rate.
#6 2017-05-31 09:09:34
i get the frist critical at 0.5465 with the shape shown attached
#7 2017-05-31 09:30:29
Msegade
That's what I was looking for!
Can you please share the .comm file?
#8 2017-05-31 09:52:14
here it is
as can see your first trial was quite out
for buckling as for may other problems code_aster looks very verbose
but can be easily fine tuned once the first .comm file has been written
#9 2017-05-31 10:46:47
Msegade
Thanks! Now I got it working.
Is there any reason why 'PLUS_PETITE' is not working?
If I use the same .comm file and I replace
modp1=CALC_MODES(
	TYPE_RESU='MODE_FLAMB',
	OPTION='BANDE',
	STOP_BANDE_VIDE='OUI',
	MATR_RIGI=mascomb,
	MATR_RIGI_GEOM=masrigv,
	CALC_CHAR_CRIT=_F(
		CHAR_CRIT=(mini,maxi,),
	VERI_MODE=_F(
		STOP_ERREUR='NON',
with
modp1=CALC_MODES(
	#OPTION='BANDE',
	MATR_RIGI=mascomb,
	CALC_CHAR_CRIT=_F(
	         #CHAR_CRIT=(mini,maxi,),
                 NMAX_CHAR_CRIT = 6,
	VERI_MODE=_F(
		STOP_ERREUR='NON',
I get bad results.
#10 2017-05-31 10:57:36
this is probably explained somewhere in the doc
without reading it
my first answer is that
as the critical buckling load factor may take negative value
it will always be possible to find a value close to "minus infinity"
which will probably be meaningless
