#1 2013-05-23 15:50:24
Zhe LI
How to calculate the internal nodal forces with the displacement field
Hello everyone,
I would like to obtain the Internal Nodal Forces with a given field of displacement.
Is there a command that can do this?
I've seen the document of the command "CALCUL()", but I don't understand why I should offer DEPL, INCR_DEPL, SIGM and VARI at the same time, as presented in the syntexe.
In fact, I would like to calculate the elementry vector of this internal nodal forces, and I want to obtain the assembled vector by using the command ASSE_VECTEUR(). Any one knows if it is possible?
Thanks for your help.
Zhe
#2 2017-02-27 09:37:48
PATCH
Re: How to calculate the internal nodal forces with the displacement field
Hi.
I have the same problem. Did you figure out how to calculate internal forces?
Michal
#3 2017-03-01 09:05:06
stephaneberger
Hi
you have to have a look on the documentation U2.04.06 : How to dig a tunnel and the test-case sslp105b.comm
You will find the methodology starting from line :
#    2EME PHASE BLOCAGE DU BORD DE LA GALERIE (OPTION DIDI)
up to the line
#        3EME PHASE = REINJECTION DE LA REACTION
regards
stephane
