Hi, My name's Jorge. I want to use the command "PRE_SIGM" to preload a bolt in a joint but I can not do it. How to create a "cham_elem"?
Thanks and sorry for my english.
Jorge
without the mesh it is very difficult to tell
Hello, Thanks. I attach the file .hdf
Hello, Thanks. I attach the file .med
try this
prett=CREA_CHAMP(
TYPE_CHAM='ELGA_SIEF_R',
OPERATION='AFFE',
MODELE=mode,
AFFE=_F(
GROUP_MA='GrMesh_2_Edges',
NOM_CMP=('N','VY','VZ','MT','MFY','MFZ',),
VALE=(10.0, 0, 0, 0, 0, 0,),
INFO=2,
PROL_ZERO='OUI',
Thank you jean pierre aubry, this is a solution!!
best regards, Jorge
i've tried to follow your advice to model the pre-load of a bolt in an example very similar to the one attached before. However in the very first iteration my bolt gets elongated by the value of the stress/modulus. What i wanted to do however was to say to CA that the linear element @start has already a stress "inside" at that fixed elongation.
Am i doing something wrong ?
For example i tried to set a negative PRE_SIGM value but then the simulation does not converge in the first iteration.
Thank you in advance,
Andrea
Am i doing something wrong ?For example i tried to set a negative PRE_SIGM value but then the simulation does not converge in the first iteration.
Andrea
i have a similar problem :
using only PRE_SIGM with out other loads it works (only for a limited range of values)
using only PRE_SIGM with other loads it doesn't work, there isn't its computation
What i don't understand ???
how to close two plates with a bolt in 3D
is the procedure right ???
if you want try to run the attached :-)
hello miib
i had a look at your problem
and i have several questions
why DYNA_NON_LINE i do not see any dynamics in this problem?
why is not there any ramp to the load?
why a COULOMB contact?
why is there a 'model' and a 'modelX'
more generally what are you trying to do ?
Hi jean pierre
because i have several DOF free ( not constrained ) and in this case, using static simulation, the matrice will be singular, DYNA with simplicity bypass this "problem".
because using in PRE_SIGMA, the "voice" VALE_F, i obtain an error that tell me which there is an inconsistency between the function's values and same points of the bodies
hello miib
it is a refuse of my precedent studies when i used a real thread in screw and nut , ( the value of preload depend by friction coefficient :-D)
hello miib
because i observed that PRE_SIGM doesn't work in the model where there is others loads, but it works using only its (without others load), so i created two models equal ( the only difference is the names) where in the first i applied all the loads with out pre_sigm , and in the second model i applied only pre_sigm, and after with proji_champ i combine the two effects, this work good.
i'm trying to close two plates with a bolt using 3D elements.
i will reply a bit later to the previous points
but
looking at the results of your analysis
it seems to me they are not realistic
did you had a look at the results just simply displacement ?
there is also a warning in the contact treatment
<A> <CONTACT2_15>
that may explain the strange results
enclosed is a modified command file that solves the problem with
adding another load
adding ramps to both loads
using one single model, the one named 'model'
in addition i have used a somehow more realistic material with simple ELAS properties
in the end this gives some more realistic displacements than your file
i still believe that a STAT_NON_LINE with soft springs would handle the problem much better
using DYNA_NON_LINE for the only reason that it solves a STATIC problem does not seems a sound engineer practice
this holds true for some other experiment you tried
if anything is not clear ask
adding another load
using one single model, the one named 'model'in addition i have used a somehow more realistic material with simple ELAS properties
using DYNA_NON_LINE for the only reason that it solves a STATIC problem does not seems a sound engineer practicethis holds true for some other experiment you tried
the problem remains
Hi jean pierre
jeanpierreaubry wrote:why DYNA_NON_LINE i do not see any dynamics in this problem?
consider that I am self-taught,
attached the error message, someone hacked me the version of code_aster ??? :-)
mah!!!
using DYNA it works :-)
i ran the problem on my own 14.4 version and it fails while it runs well on 15.2 version
the most probable reason is that one
! <A> <CONTACT2_15> !
! Contact discrete formulation. !
! The contact zones number 2 and number 4 have 20 nodes common to their surfaces slaves. That can !
! sometimes lead to a singular contact matrix. !
! If computation had suddenly failed, check the definition of your contact surfaces or !
! inform one of key words SANS_NOEUD/SANS_GROUP_NO/SANS_MAILLE/SANS_GROUP_MA. !
! This is a warning. If you do not understand the meaning of this !
! warning, you can obtain unexpected results! !
it concerns surfaces 'sv' and 'si'
you should create a group of these common nodes and use SANS_GROUP_NO as stated in the message
you should always read completely the message file when things go wrong!!
anyhow enclosed is a .comm file that creates this GROUP_NO (at the beginning) and runs on 14.4
once this done you should have a look at the results
to my opinion they are physically meaningless
try to find out why!!
ok :-)
solved se attached, the problem in my version 14.4 remains (is the same with 13.6) :-)
right, time step is not realistic :-)
you will never get any results if you keep not applying the modifications i suggest
when i speak of physically meaningless
i mean that the calculated displacement are strange to my eyes
you cannot have an opinion about a result you do not obtain
and you do not have a problem of time step but a problem of not applying the SANS_GROUP_NO in the contact
once you get a result we may talk of the many other things that are not really good in your study
you cannot have an opinion about a result you do not obtainand you do not have a problem of time step but a problem of not applying the SANS_GROUP_NO in the contact
fais-tu de la politique ? :-D
toutefois
il n'en reste pas moins qu'avec STAT_NON_LINE ça ne marche pas alors qu'avec DYNA_NON_LINE ça marche et voilà les résultats (voir pièces jointes)
Sur le sens physique peut-être ok : en réalité le boulon est en traction, dans la simulation et en compression mais je m'intéresse à la fermeture des plaques, et non le boulon en traction.
eh bien oui ça ne marche pas
en autre avec PRE_SIGM qui semble ne pas être admis avec DYNA_NON_LINE
c'est écrit dans U4.44.01 au chapitre PRE_SIGM
on ne peut pas détourner les opérateurs de ce pour quoi ils sont fait
cependant le fichier que j'avais joint tourne avec des résultats très cureiux par rapport à ce que je crois être la réalité physique du problème
l'iamge que vous joigné montre un maillage horrible ! ou je me trompe ?
oui, les maillages ne conviennent pas à un calcul précis mais ils conviennent à un calcul rapide (démonstration)
Considérant que votre schéma de calcul avec STAT_NON_LINE dans mon software ne fonctionne pas, mais ne fonctionne qu'avec DYNA_NON_LINE, d'après votre expérience il est permis d'utiliser PROJI_CHAMP sur PRE_SIGM, je pensais au principe de superposition des effets.
mon expérience me dirait de ne pas dévoyer les opérateurs
le fait qu'un opérateur (ici DYNA_NON_LINE) donne un résultat n'est en aucun cas une preuve de la validité de la démarche !
de fait je ne sais pas trop bien interpréter la remarque de la doc à propos de PRE_SIGM
pour ma part j'ajouterais au maillage quelques ressorts assez mous pour bloquer les mouvement de corps rigides des corps qui en ont
ce n'est pas la mer à boire et c'est la solution généralement admise
certains softwares ajoutent ces blocages d'eux mêmes d'une manière pas très transparente
code_aster ne fait jamais cela à votre place, a vous de le faire
ok, je m'engage à ne pas faire un usage abusif des opérateurs :-)
bon, je ne vous demande pas de perdre du temps à m'apprendre comment le faire, mais gentiment je vous demande un link (pdf, etc) pour apprendre à le faire avec code_aster, en d'autres termes gentiment je vous demande du matériel d'étude. Je n'ai PAS lu votre livre en entier, n'est-ce pas ? (si je ne comprends pas, je demanderai des informations ici) :-)
oui, par exemple, j'ai vu qu'Autodesk Inventor le fait dans son simulateur intégré (je suis un CAD designer).
