Hi everyone
How to install paraview with med plugin
Advance thank you for your fast response
Warm Regards
venky
you can use Salome Meca's paravis module inside Salome to open Med files.
Paraview standalone does not support Med files
Mechanical Engineer, Independent Software Developer - searching for contracts as Freelancer
There is a Paraview Med : http://www.alneos.com/en/downloads/paraview-with-med
See this thread:
http://code-aster.org/forum2/viewtopic.php?id=20676
/C
Opensuse 15
http://www.caelinux.org/wiki/index.php/Contrib:Claws/Code_Aster
Hi
Thanks for your replay
when using paraviz in salome meca myself i found some what loading problem as well i can't see grouping but in the paraview
looks easy to handle any complex geometry and i am getting grouping also.
see the png below
You can run paraview from salome environment. Open a terminal and type:
salome shell
paraview
