#1 2015-08-30 04:33:59
Humberto
Basement Wall with Triangular Loading
I am modelling a Basement Wall system with Triangular loading as the soil pushing on the face of the wall,
The model is working and I get correct Deformations, I actually built this same model on a scale of 1:1, loaded it with Hydrostatic pressure and tested for the deformation, the Code-Aster value was within 1mm to the real measured one!!!
Now for some reason I can only see stresses on the 3D part of my mesh, and no stressses for the 2D DKT elements.
Here is my Study File:
https://drive.google.com/file/d/0B3df_K … sp=sharing
Here is my Command.com:
Here is my Mesh New_case.mmed:
How Can I see the stresses on the 2D mesh?
Regards.
Humberto H.
#2 2015-08-31 07:52:38
Re: Basement Wall with Triangular Loading
this is explained in my book at page 100
#3 2015-09-01 19:35:29
Humberto
Thanks Jeanpierreaubry: I was still having problems after reading those pages, but decided to go ahead and study the whole book agian, hopefully I will be able to print them in the .RMed  file.
Thanks for your response anyways.
Humberto
#4 2015-09-08 20:18:24
Humberto
jeanpierreaubry: Thanks, I went through your book and I tried several different ways, and couldn't get it to work. Maybe it is because I used a NetGen 3D for the 3D panels and Quadrangular 2D  for the DKT elements, I am so confused.
Anyways As long As I know (from your book) the Displacement and stresses are automatically calculated in the MECA_STATIQUE Call but I just can not see the stresses!
The displacement looks good.
If someone could throw some light I would really appreciate it.
Humberto
