#1 2014-07-15 19:35:00
katoulos
Usage of FIN - POURSUITE
Hi there
I am reading the documentation but, as usual with practical issues, it is impossible to undestand how to do this:
is it possible to
   (a) run a computation, say, on Monday, save the result on some file, then
   (b) do some post-pocessing, on Friday?
   (c) if yes, how exactly can one do it?
Thanking in advance
mimis
P.S. too many things are mentiioned in the manuals elusively and it's impossible to understand what happens:
1     the file "glob.1" is mentioned in U4.11.02, prgr#3 : no mention is done on how one may keep it and feed it
       to a future calculation where, as I understand it, POUSUITE will read it - or is this all wrong
  2   the RETASSAGE option: could not find it's meaning - even dictionaries don't have it
#2 2014-07-15 22:07:45
Re: Usage of FIN - POURSUITE
In a nutshell, the answer is yes. You may read U1.03.00 for more detailed information, especially section 3.6.
#3 2014-07-15 22:19:23
katoulos
Thank you very much !
If I may ask one more favour: could give me a rough idea of the meaning of RETASSAGE in French?
mimis
#4 2014-07-16 00:46:39
delmas
Retassage means to compact.
Code_Aster release : unstable on (Ubuntu Precise Pangolin 12.04 64 bits) - GNU + Intel
Code_Aster. What else ?
#5 2014-07-16 11:04:30
katoulos
well, sorry to have to get back to the forum about this but:
I understand that using IMPR_RESU will save a result post-processing is possible by a different comm file. This is, I understand, the classic way.
However, I expected to be possible to make a total copy of the session objects and python variables so as to take it up later or, send it over to someone else: I tried
DEFI_FICHIER ( ACTION     = 'ASSOCIER',
               FICHIER    = '/home/projects/fracture/1/cyli-1.hdf',
               UNITE      = 99,
FIN ( RETASSAGE  = 'OUI',
       INFO_RESU  = 'NON',
       FORMAT_HDF = 'OUI',
       UNITE      = 99 ,)
but, the hdf file I get, is empty. What is the concept behind telling FIN to use a hdf-format file? is it about saving something?
thanking everyone in advance for their patience :-)
mimis
#6 2014-07-16 12:51:45
if you take the patience to read my book
http://framabook.org/14-beginning-with-code_aster/
you will find the answer to your questions
