Hello All,
I want to apply boundary conditions defined by an oblique coordinate system. The documentation states that I can define all 6 DOFs under one LIAISON_OBLIQUE statement ( "¦" is used in the docs, not "/" when listing DX, DY, etc). EFICAS only allows one DOF definition per LIAISON statement and Aster v11.2 aborts if I try to force more than one DOF into a single statement. Is this a bug in the documentation?
Gary
Ubuntu 12.04
Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz
Indeed the catalog forbids to apply more than one dof at a time (you need to repeat the factor keyword to workaround this).
However the source code seems to allow it.
We'll have a look at this and unlock the feature if possible.
Thanks for the feedback.
Corrected in revision 12.05
