#1 2012-06-30 20:10:14
toltec
[Solved] COQUE_3D Post Processing
I'm trying to post process a COQUE_3D analysis and have one again run into the problem that neither Paravis nor PostPro can do this directly:
1) Is there a work flow that works for Paravis? Or for that matter PostPro?
2) I've tried PROJ_CHAMP as below to create linear element results, but this doesn't work for triangles. The tri's don't take on a resultant value( deformation or stress). Does anyone know how I can fix this?
lin_mesh=CREA_MAILLAGE(MAILLAGE=m_quad,
                       QUAD_LINE=_F(GROUP_MA='m_all',),);
lin_pall=AFFE_MODELE(MAILLAGE=lin_mesh,
                     AFFE=_F(GROUP_MA='m_all',
                             MODELISATION='3D',),);
PROJ=PROJ_CHAMP(RESULTAT=STATIC,
                MODELE_1=pallet,
                MODELE_2=lin_pall,);
IMPR_RESU(MODELE=lin_pall,
          FORMAT='MED',
          RESU=_F(MAILLAGE=lin_mesh,
                  RESULTAT=PROJ,
                  NOM_CHAM=('SICO_ELNO','SIEQ_ELNO','EPSI_ELNO','SIEQ_NOEU','EPSI_NOEU','DEPL','SIEQ_ELGA',),),);
Thanks for the help.
Gary
Ubuntu 12.04
Intel(R) Core(TM)2 Quad CPU    Q9400  @ 2.66GHz
#2 2012-07-01 23:21:22
Re: [Solved] COQUE_3D Post Processing
Paravis should work, what is the problem ?
Using PROJ_CHAMP is of course a good idea but why don't you project on a quadratic mesh (QUAD8 or TRIA6) ? This should be OK.
#3 2012-07-02 08:42:09
toltec
Hi Thomas,
Many thanks for your reply. If I don't use PROJ_CHAMP Paravis displays the element central nodes with a zero result. I've now projected the results to my original quadratic mesh (no central nodes) instead of to a linear mesh and it works perfectly. I really like Paravis.
Thanks again.
Gary
Ubuntu 12.04
#4 2012-07-04 20:38:59
keeswouters
hoi Gary
can you give the code (comm file) of how you implemented this projection here?
kind regards - kees
kind regards - kees
#5 2012-07-04 21:48:59
toltec
Greetings Kees,
Comm file attached! Hope it's what you're looking for.
Cheers
Gary
Ubuntu 12.04
#6 2012-07-05 18:35:12
keeswouters
Hoi Gary
I glanced through the code and for now it is just what I am looking for.
Thank you for the upload. I will check the relevant part for me later on (it is holliday season for me as well).
Kind regards - kees
kind regards - kees
