#1 2011-11-11 13:53:42
JMB365
Tmp directories specified in asrun
I am trying to understand the purpose, function and implications of the various values for specifying temporary directories in the ../etc/codeaster/asrun file; for example:
# Directory shared by all compute nodes and used as a proxy between then
# clients and the server : clients upload data files into this directory and
# download results files from it. For example : /export/tmp/PROXY_DIR...
proxy_dir : /tmp
# root of temporary space for astk services
rep_tmp : /tmp
# Temporary directory for Aster executions
rep_trav : /tmp
# Temporary directory for Aster executions shared by all processors
# (used by mpi executions). For example : /export/tmp, /home/tmp...
shared_tmp : /tmp
# shared folders = for which remote copy is never necessary (comma separated)
shared_folders :
Can somebody explain to me or point me to the right Doc file (if there is one) so I can better understand the what/why/how of these variables, especially in the light of configuring OpenMP / MPI clusters?  What I have read so far as comments in the file do not fully explain the purpose or nuances of changing these values from their default values.  So far I have understood what the function of shared_tmp is from jcugnoni's posting.  I am trying to grasp what the others are.  Thanks.
Regards, JMB
SalomeMeca 2021
Ubuntu 20.04, 22.04
#2 2011-11-14 16:16:30
mathieu.courtois
Re: Tmp directories specified in asrun
First, on a stand-alone configuration (only one computer), all these fields should be set to a local temporay directory (usually /tmp or another one with sufficient space and on a quick hard disk).
The comments should be sufficient for advanced users.
proxy_dir : is only used when a remote client starts a calculation on the current server. The data and result files will be copied in this directory. It should be shared by the compute nodes.
rep_tmp : only used for small files for as_run. Should be on a local partition.
rep_trav : will contain the working directory during Code_Aster executions. It's important that it should be very quick and have a sufficient capacity. So it must be local to every node.
shared_tmp : used for MPI parallel executions. It must be shared by all nodes. The main working is prepared in the directory and then copied locally on each processor (in a subdirectory of rep_trav).
Typically, we have :
proxy_dir : /scratch/tmp  (shared by all the cluster nodes)
rep_tmp : /tmp
rep_trav : /tmp
shared_tmp : /scratch/tmp
MC
#3 2011-11-14 20:37:24
JMB365
Hello courtois, Thank you for the details.  It is clearer now.  Regards, JMB
SalomeMeca 2021
Ubuntu 20.04, 22.04
