Hello All,
I'm debugging a 3D static non-linear mechanical analysis and want to print VMIS and V1 results to the resu file for a single element. I have placed this element (M66948) in a group called base_e in Salome and reference it in the .comm file. CA instead prints results for element M86187. Attached are the .comm and .resu files.
Am I misunderstanding something or is this incorrect?
Many thanks to anyone who may look into this!
Gary
Ubuntu 12.04
Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz
well this may be normal
as long as this is the element you want!
numbering in aster is different from mesh number in a med file
try this
in Salome mesh module pick an element get its properties,
in Post-Pro module pick the same element and get its properties
that is why one should always use groups
Hello Jean Pierre Aubry,
Thanks for this info, I was unaware that element numbers could change. My analysis seems to be behaving itself now.
Thanks again.
Gary
Ubuntu 12.04
