Hello All,
I've compiled CA with GNU & Intel v11.1 compilers and MPICH2. With mpi_nbcpu=1 the executable gives similar runtimes to a sequentially compiled one which is good news. However if I set mpi_nbcpu=2 runtime is MUCH longer (out of core, no swap used).
The .mess file shows:
Version parallèle de Code_aster compilée avec MPI
Exécution sur le processeur de nom gary-desktop-LTS de rang 0
Nombre de processeurs utilisés 1
Shouldn't the second rank show rang 1?
I have my suspicions about this because I have to use the openMPI option:
mpi_get_procid_cmd : echo $OMPI_MCA_orte_ess_vpid
to get the code to run as $PMI_RANK doesn't work. This seems odd!?
Any observations would be appreciated.
Gary
Ubuntu 12.04
Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz
mpi_get_procid_cmd is used by as_run to prepare the environment, start the execution...
This message is directly printed by the Code_Aster executable using the mpi library (see python.c) :
MPI_Comm_size(MPI_COMM_WORLD, &nbproc);
MPI_Comm_rank(MPI_COMM_WORLD, &me);
MPI_Get_processor_name(processor_name, &namelen);
printf("\n Version parallèle de Code_aster compilée avec MPI\n");
printf(" Exécution sur le processeur de nom %s de rang %d\n",processor_name,me);
printf(" Nombre de processeurs utilisés %d\n",nbproc);
Some ideas :
- check the mpirun command used by as_run (the mpi script should be dumped in the .e(rror) file of the job).
- try to reproduce the problem with a very simple executable...
MC
Hello MC,
Thanks for the reply. It seems that there is a problem in the way mpich2 is launching the processes. Setting mpi_nbcpu=4 (for eg) results in the following message repeated four times in the *o* temporay file:
"Version parallèle de Code_aster compilée avec MPI
Nombre de processeurs utilisés 1"
So, four identical processes are launched it seems.
I have recompiled using the GNU compilers only (with MKL) and CA runs fine. The single message in the *o* file is:
Exécution sur le processeur de nom gary-desktop-LTS de rang 1
Nombre de processeurs utilisés 4 "
I suspect this has something to do with mpi_get_procid_cmd : echo $PMI_RANK not working,
I'll keep trying... I want the Intel MPI version to work and feel it must be close!
Gary
Ubuntu 12.04
