#1 2011-01-19 16:53:15
rcbsimoes
astk status
when i run the job from astk, how do i check the current job status??
still running or stoped.. or what ever..
rui
ps. usualy i look at the cpu performance (top command in a text window), but that's not very pratical nor correct is it?
#2 2011-01-19 17:11:09
Re: astk status
the best way is to check the" interactive follow up" box this should open a terminal printing what's going on
this may not work if the install is not correct in this respect
if this does not let me know i will try to help you solve
bext possibility: in the ASJOB window select you job in the upper part window and push "Rechercher" this should print the on going command in the lower part window
#3 2011-01-19 18:55:30
rcbsimoes
Re: astk status
didn't try this:"to check the" interactive follow up" box", because it doesnt work in salome...
but thanks for your help, i'll try the tips!
rui
#4 2011-01-19 19:13:09
tcdonley
Re: astk status
Hi Rui,
Steps 5 and 6 of this wiki page may help you to get interactive follow up to work. If it doesn't work in Salome it probably won't work in ASTK either.
Here's the wiki page:
http://www.code-aster.org/wiki/doku.php … 0_compiled
If you're not running Ubuntu, then step 6 about gdm.schemas may not be valid for your operating system. You have to allow your computer to "listen' for TCP requests.
Best,
Tim D.
#5 2011-01-20 07:42:32
Re: astk status
this is  not true, as on my machine "interactive follow up" works fine from ASTK either the aster based one or the Salome-Meca based but does not work from a "Run" in the tree of Salome-Meca
i had a quick look at the wiki, impressive job:
however i solved the problem in a different way :
window ASTK menu "Configuration" > "Preference" < "Network" then
the box "Client machine name" to your machine name  ( command hostname in a terminal)
"Domain name" may be empty (i assume a stand alone machine)
"Forced DISPLAY variable to ":0.0", very important!
"rsn" and "rcp" ON
the rest of the install i do it entirely as normal user
then "su" extract to /opt run the install and post install scripts
NEVER launch the apllication from this terminal as a test, go back as noraml user to try out
i found out that the permission are right from the start using this way
i proceed like that for years' since 2007 on various SuSE distributions
