#1 2010-12-30 18:58:13
rcbsimoes
teste case
Hi All,
as i was doing same simple exercises to compare results from Ansys to Code Aster, I found this doc:
http://www1.ansys.com/customer/content/ … a_vm90.pdf
if you look to case VM5, they state the stress at mid-lenght should be 8,333 psi.
i've done the same exercices in Salome Meca, but I cant get the same results.
done it with 2D_plane and 3D solids, both solutions reaching the same results, witch are .59in max displacement, and 50.5kpsi for max stress (von mises).
how came the results are so different??
i belive my solution has converged OK. tested it with diferent meshes and they all came to the same results.
would ansys state a stress witch is not the maximum??
i'll try to attach my files.
rui simoes
#2 2010-12-30 23:04:21
Claws
Re: teste case
I gave D_PLAN a try on some models the other day, and I just gave the ansys wm5 test a try now.
As per your other post http://www.code-aster.org/forum2/viewtopic.php?id=9289 I obtain 16737 / 2 = 8368psi normal-stress (sixx) which is pretty close to the manual target of 8333psi.
I don't know however, how to interpret the displacement. Divided by two as well? I don't even know how to read the Ansys result right now O_o
btw., I've stayed with IPS - haven't tried a conversion to mmNS or MKS
Claus
Opensuse 15
http://www.caelinux.org/wiki/index.php/Contrib:Claws/Code_Aster
#3 2010-12-31 01:53:14
rcbsimoes
Re: teste case
Hi Claus,
could you post me your geo+mesh+comm??
cant reach the same results..
thanks
rui
#4 2010-12-31 08:14:54
Claws
Re: teste case
Why yes, yes I can smile
Claus
Opensuse 15
#5 2010-12-31 16:03:55
rcbsimoes
Re: teste case
thanks claus!!!
the difference was, you used force_nodal and i was using a force_contour applied to an edge.
i thought this contour force, would divide the force by the edge length and minor the local deformation and increase in stress...
apparently i was wrong! changed it to force nodal and there it was, SAME RESULT as you and as Ansys.
thanks again for your help!
rui
ps. happy new year!
