There is probably some other threads similar to this, but I found nothing so specific.
What I would like to do is to apply nodal forces to single nodes inside a loop. The nodal force will be dependent from the node coordinates so we need to access them.
We can resume the steps as follows:
- get a node id list from a GROUP_NO
- loop trough for each node in the list
- get the node coordinates
- apply a nodal force computed using the node coordinate
Do you know how to do that?
Thanks in advance!
1. If load on all nodes is same then you can simply use FORCE_NODALE over the GROUP_NO under AFFE_CHAR_MECA
2. If load on nodes follow some relation, still you can use above keywords in AFFE_CHAR_MECA_F where you can define the variation of load.
3. If Variation is arbitrary, extract the values in a python list and make this list as DEFI_LIST_REEL. Then use this list to apply load on node in AFFE_CHAR_MECA_F
Thanks for the answer,
I was thinking about using more python to do such operation, but it will be a waste of time. AFFE_CHAR_MECA_F will work fine.
Thanks again!
Thanks again!
Great to know that it solved your problem.
It would be great if you can edit your first post and change the subject adding [SOLVED] to it. It will help others.
Well,
it took me a while to figure it out, but I found a general way, maybe not the most elegant, but a working one.
Suppose you have a vector (or python list, whatever) named "F" and containing the forces you want to apply. You also have a group named 'Fz in which you want to apply forces in Z direction. Of course the number of elements in F equals the number of nodes in in the "Fz" group.
All it takes is:
from partition import * #you need to have the aster/STA9.4/bibpyt/Utilitai in the search folder
MAIL=LIRE_MAILLAGE(FORMAT='MED',);# Reading the mesh file in Aster Format
mesh1 = MAIL_PY()# Creating empty new MAIL_PY "class istantiation"
mesh1.FromAster(MAIL)# Reading mesh Data From Aster using object referencing to the class function FromAster
NodeGroup = mesh1.gno # extracting nodes group (see help(MAiL_PY) for object methods reference)
Fznodes = list(NodeGroup['Fz'])# extracting all ids' of the Fz nodes group
forcelist=[];#empty python list to nitialize the BC forces list
c=0 # F iterator
for i in Fznodes : #loop trough all nodes int he group
forcelist.append(_F(NOEUD = 'N%d' % (i),FZ=F[c],),) #add to the list the code aster macros for nodal forces
c=c+1#next iter next F element
print forcelist[0] #check the format
CHAR=AFFE_CHAR_MECA(MODELE=MODE,
DDL_IMPO=(_F(GROUP_NO='fixed',DX=0.0,DY=0.0, DZ=0.0,),
_F(GROUP_NO='slidey',DY=0.0,),),
FORCE_NODALE=(forcelist), #that's all!
Hope it helps!
Ciao
