Okay, I understand that.
The newest stable version seems to be 15.5.0 ? (htt ps://sourceforge.net/p/codeaster/src/ci/stable/tree/) If that doesn't work with the newest salome_meca 2021.0.0-2-20211014 container then try it with older salome_meca 2021.0.0-0-20210601 container. Hope it works !
VonPire
well, I was quite positive when everything compiled and built correctly (I had to --disable-petsc also). But in the end, there was no MUMPS compiled, which I overlooked. So, that doesn't work (15.5 and the newest container),
According to https: //gitlab.com/codeaster-opensource-documentation/opensource-installation-development/-/blob/main/devel/changelog.md there is comparability of aster and singularity container images.
starting from 16.0.12:
salome_meca-lgpl-2021.0.0-2-20211014-scibian-9
starting from 16.0.6:
salome_meca-lgpl-2021.0.0-1-20210811-scibian-9
starting from 16.0.0:
salome_meca-lgpl-2021.0.0-0-20210601-scibian-9
starting from 15.3.17:
Hallo!
I also tried the MPI compilation described in:
https: //github.com/emefff/Code-Aster-MPI-in-Singularity-of-SM2021
and by disabling MFRONT it worked (without disabling MFRONT I got an error message regarding META_LEMA_ANI.cxx).
However, after runnning:
singularity run --app install salome_meca-lgpl-2021.0.0-0-20210601-scibian-9.sif
./salome_meca-lgpl-2021.0.0-0-20210601-scibian-9
stops with:
OSError: [Errno 30] Read-only file system
singularity exit code: 1
Any suggestions what the problem is?
Many thanks in advance!
