lIlIl
December 9, 2024, 12:47pm
21
@lIlIl To answer my own question: you can use the --fakeroot Singularity option.
$ singularity run --fakeroot ~/sm22/salome_meca-lgpl-2022.1.0-1-20221225-scibian-9.sif shell
Converting SIF file to temporary sandbox...
Singularity> whoami
root
Singularity> groups
root
Singularity> id
uid=0(root) gid=0(root) groupes=0(root)
Could you explain briefly how --fakeroot works? Will I be able to change some python files inside the image and will the change be permanent?
lIlIl
December 9, 2024, 2:15pm
23
It seems that all changes are temporary. It only simulates root privileges, it doesn’t actually modify the underlying file system. This is part of what makes Singularity safer than Docker images.
@lIlIl I was afraid of that because of the sandbox word in your post
lIlIl
January 7, 2025, 5:16pm
25
Does anyone know where mfront is stored? I would like to call mfront --obuild but I can’t find it.
I used find in the root of the WSL distribution and it outputs:
./home/user/dev/codeaster/src/mfront
./home/user/dev/codeaster/src/build/mpi/release/mfront
./opt/public/20221225/gcc8-openblas-ompi2/.installed/mfront
./opt/public/20221225/gcc8-openblas-seq/.installed/mfront
But none of them are executable.
mf1
January 7, 2025, 5:36pm
26
@lIlIl
within the container in the ‘/opt/salome_meca/’ folder do a ‘find . -type f -executable | grep mfront’ which will give you all executable files with mfront in the name.
In my case I get:
./V2022.1.0_scibian_univ/prerequisites/Mfront-TFEL340/bin/mfront-3.4.0
./V2022.1.0_scibian_univ/prerequisites/Mfront-TFEL340/bin/mfront-doc-3.4.0
./V2022.1.0_scibian_univ/prerequisites/Mfront-TFEL340/bin/mfront-query-3.4.0
./V2022.1.0_scibian_univ/prerequisites/Mfront-TFEL340/lib/python3.6/site-packages/mfront_3_4_0/init .py
./V2022.1.0_scibian_univ/prerequisites/Mfront-TFEL340/lib/python3.6/site-packages/mfront_3_4_0/mtest/init .py
./V2022.1.0_scibian_univ/prerequisites/Mfront-TFEL340/lib/python3.6/site-packages/mfront_3_4_0/umatxx/Behaviour.py
./V2022.1.0_scibian_univ/prerequisites/Mfront-TFEL340/lib/python3.6/site-packages/mfront_3_4_0/umatxx/init .py
./V2022.1.0_scibian_univ/prerequisites/Mfront_testing-TFEL343/bin/mfront-3.4.3
./V2022.1.0_scibian_univ/prerequisites/Mfront_testing-TFEL343/bin/mfront-doc-3.4.3
./V2022.1.0_scibian_univ/prerequisites/Mfront_testing-TFEL343/bin/mfront-query-3.4.3
./V2022.1.0_scibian_univ/prerequisites/Mfront_testing-TFEL343/lib/python3.6/site-packages/mfront_3_4_3/init .py
./V2022.1.0_scibian_univ/prerequisites/Mfront_testing-TFEL343/lib/python3.6/site-packages/mfront_3_4_3/mtest/init .py
./V2022.1.0_scibian_univ/prerequisites/Mfront_testing-TFEL343/lib/python3.6/site-packages/mfront_3_4_3/umatxx/Behaviour.py
./V2022.1.0_scibian_univ/prerequisites/Mfront_testing-TFEL343/lib/python3.6/site-packages/mfront_3_4_3/umatxx/init .py
So, it should be one of these, I think.
Mario.
lIlIl
February 5, 2025, 4:15pm
27
@mf Thank you! I was able to locate mine. However, I run into errors…
Singularity> ./mfront-3.4.0
./mfront-3.4.0: error while loading shared libraries: libTFELMFront-3.4.0.so.3.4.0: cannot open shared object file: No such file or directory
Singularity> ./mfront-4.1.0
./mfront-4.1.0: error while loading shared libraries: libTFELMFront-4.1.0.so.4.1.0: cannot open shared object file: No such file or directory
I’m stumped.
