#1 2017-09-11 16:13:24
godar
[SOLVED] Connecting several meshes for AFFE_CHAR_THER_F
I am searching for a method to connect several meshes for AFFE_CHAR_THER_F. There is no LIAISON_MAIL in AFFE_CHAR_THER_F.
I am trying to make a transient heat analysis. The reason I have several meshes and not one big mesh is that I could not mesh the larger geometry. I was only able to mesh parts of the geometry (once the mesh was chosen fine enough). The meshes are not-matching on the areas where I wish to connect them.
Does anybody know how one would solve such a problem?
Thank you
#2 2017-09-12 23:01:54
Johannes_ACKVA
Re: [SOLVED] Connecting several meshes for AFFE_CHAR_THER_F
Which analysis command do you use: THER_LINEAIRE or THER_NON_LINE?
Simply define 2 load concepts:
AFFE_CHAR_THER_F(containing the loads depending on variables)
AFFE_CHAR_THER(  LIAISON_MAIL )
and include them both in the analysis command
Johannes_ACKVA
______________________________________________________________________
CODE-ASTER-courses at Ingenieurbüro für Mechanik, Germany
*** CODE-ASTER INTRO + CONTACT + MATERIAL
     09-13 October 2017
*** CODE-ASTER  DYNAMIC ANALYSIS
     30 Nov - 01 Dec 2017
#3 2017-09-13 09:11:59
godar
thank you for your response. I will give it a try.
I am using THER_LINEAIRE.
Kind regards
EDIT:
It works. Thank you
